ALIENTEK D8 Full Digital Amplifier FDA STA326 USB XMOS Class D 2x 80W / 4 Ohm Silver
4.1 / 5
Reference : 11828
139,00 €tax incl.
115,83 € tax excl.
The FDA Class D amplifier STA326 DDX Alientek D8, complete controllable via remote control, integrates as standard an analog digital converter PCM5122.
Associated with an S / PDIF interface WM8805 with a jitter of 50ps, an interface USB XMOS on a separate card, this integrated amplifier opens the door to High Definition at a democratic price.
The quality of its components is high-level with a 12dB analog filter at the output of neat amplification featuring film capacitors, armored coils Miden 8A limiting the noise noise on the harmonics.
Analog input capacitors are audiophile quality Elna. The Alientek D8 will also be a desktop companion with headphone amplification MAX9722 in 6.35mm jack capable of "driver" sedentary models with high impedance.
It has three digital inputs (USB, S / PDIF coaxial and Toslink optics).
Its bright, readable OLED display displays in real time the source used as well as the sampling rate of the audio file being played.
This all-in-one amplifier is also equipped with a digital equalizer with many functions (bass, treble, mute etc.) adjustable directly from the remote control.
hewill prove to be the ideal companion for any digital source.
Hisergonomics, sa compacity are notable assets, plus its versatility.
The Alientek D8 amplifier is OTG (USB input) compatible with Android smartphones.
Disconnect speakers and listen to headphones:
To be able to switch off the loudspeaker output by connecting a headset, you must do the following:
  • Go to menu 6 (Double click on the volume button),
  • To choose NO, and exit the menu correctly with Exit,
  • After selecting NO, the "Mute" function on the remote control will deactivate your speakers but not the headphone output. So you can listen to the headphones without the speakers back.
Alientek D8 review by Qobuz
" This Alientek D8 amplifier fits perfectly into the line of the new digital amplifiers and we appreciated its sound qualities on speakers, as well as on headphones, and also the possibilities offered by its display, while its many equalizations may prove useful if necessary. "
Test Qobuz
This amplifier emits a slight breath into the speakers during silent passages in the music. Although the phenomenon is very slight, it is still important to take into account when using desktop speakers with close listening.
When the XMOS driver is installed on Windows 10, it may be necessary to disconnect and reconnect the USB to be detected at startup. The problem does not arise with the default driver included in W10.
Features :
  • S / PDIF Interface WM8805
  • Interface USB XMOS U8 (24bit / 192kHz)
  • Analog to digital conversion input: ADC AK5358
  • DSP ARM Cortex M3 32 bit programmable
  • DAC PCM5122 112dB: Technical document in attached file below
  • Headphone Amplifier MAX972232 Ohm 130mW
  • OLED Display 1.3 "
  • Displaying sampling rate
  • Digital equalizer (bass adjustment -12dB to + 12db) (treble -12dB to + 12db)
  • Low-noise filter capacitors
  • Amplifier module STA326 : 2 x 80W at 4 Ohm, 2x 50W at 8 Ohm
  • Filter Capacitors Power:Nichicon 4700μF
  • Signal to Noise Ratio (SNR): 100dB
  • Frequency response: 20Hz - 22kHz
  • Supplied remote control or rotary encoder
Secondary functions:
  • Auto Standby and Start Support
  • Detection protection system on speaker terminals
Digital and analog inputs:
  • Inputs: S / PDIF Optical Toslink, Coaxial and USB-B
  • RCA Plated Analog Inputs Gold
  • Outputs HP: On screwed terminal blocks supporting banana plugs 4mm
  • Headphone Jack Jack 6.35mm
  • Supplied 28V 4.3A Power Supply
Dimensions and weight:
  • Dimensions: 140x108x32mm
  • Weight: 1200g
  • Color facade: Silver
  • Bundle: USB-A to USB-B / 4 Gold-plated Bananas / Remote Control and Power Supplies included
OutputSpeaker terminal
OutputJack 6.35mm
ColorSilver
Channel2 (Stereo)
ClassFDA
Amplifier chipSTA326
Power (W)80.0
Remote ControlYes
17 reviews
Fiabilité à revoir
Petit ampli par la taille mais grandes capacités musicales : puissance et clarté.
Hélas la fiabilité n'est pas parfaite, la sortie casque de mon précédent exemplaire n'a tenu qu'un peu plus de deux ans. Juste le temps de la garantie...
This review has been posted for ALIENTEK D8 Full Digital Amplifier FDA STA326 USB XMOS Class D 2x 80W / 4 Ohm Silver
3 mois plus tard : parfait
Le titre pourrait se suffire à lui-même mais je vais un peu détailler.
Ce qui m’a attiré au départ c’est la connectique parfaitement adaptée à mon usage : TV sur la fibre optique ; platine vinyle sur l’analogique ; RPi + serveur MPD sur USB. Le prix très attractif aussi.
Les enceintes sont des quarts d’ondes diy (90dB/W/m) qui donnent tout leur potentiel avec ce petit ampli bien cool.
Les plus : petit, consomme peu, facile à prendre en main et à utiliser, s’allume tout seul quand on a la bonne source de sélectionnée, s’éteint tout seul quand il n’y a plus de son, puissance très suffisante pour une utilisation quotidienne ; télécommande ok…
Les moins : un peu de souffle sur l’entrée analogique RCA qui s’efface dès qu’on passe le 10/12 en volume, pas de souffle audible sur les entrées numériques ; les presets ne sont pas fabuleux et je reste un flat avec les réglages eq à zéro ou éventuellement +2dB sur les basses ; l’écran en affichage en spectre est mal foutu, c’est en linéaire et ça va de 100Hz à 20kHz, donc pas d’affichage du bas de spectre et le linéaire c’est pas très représentatif ; l’éran pourrait être moins lumineux (ou réglable en intensité). Ne s’allume pas en auto si on a pas le bonne source sélectionnée précédemment.
Divers : je n’ai pas testé le casque, je n’écoute pas de musique au casque. Ce petit ampli donne avec mes enceintes sont plein potentiel à partir d’un niveau de 20/25 (faut avoir de gentils voisins), le son est très percutant sans être agressif.
Content de cet achat, il fait le job, il est discret, il est pratique.
Quoiqu'il en soit, une bonne entrée dans le monde du FDA!
Très déroutant comme ampli, la restitution sonore et la puissance sont parfait pour mes enceintes (monitoring passive DIY avec haut-parleur coaxial , sensibilité 89 db, puissance admissible 100 W), une modification de la courbe cible proposé par un certain Dominique P.(ceux qui savent le reconnaîtrons) et vous avez une qualité musicale indéniable (cela reste mon avis) pour un coût modeste. En ceux qui concerne les bruits de fond après plusieurs test, rien à signaler,aucun bruit. Je précise que je suis sur Linux (Ubuntu Studio),l' USB Xmos est reconnu directement sans manipulation, avec le bon taux échantillonnage en sortie. Pour 115 Euros, Le bonheur des petites bourses. Pourvu que ça dure.... et merci à Audiophonics.
Puissant, mais tout à fait inadapté à l'écoute à volume faible ou modéré
L'avertissement sur la fiche produit "Cet amplificateur émet un léger souffle dans les enceintes lors de passages silencieux dans les musiques. Bien que le phénomène soit très léger il est tout de même à prendre en compte en cas d'utilisation d'enceintes de bureau avec une écoute proche." est de mon point de vue un euphémisme.
Pour moi cet ampli est simple inutilisable à volume modéré (~50dB ? Je n'ai pas d'appareil de mesure précis, ça correspond aux 5 ou 6 crans de volume les plus bas de l'ampli en gros), le bruit de fond (du souffle) est trop présent, autrement dit dans le cadre de cette utilisation, c'est écoutable bien sûr mais d'une qualité vraiment pas terrible.
Pas un problème à volume plus élevé car le son de la source recouvre alors totalement le bruit de fond.
Du côté des qualités : cet ampli est à la fois pas très cher, très compact et très puissant pour son prix.
Note de 3/5 mais bien sûr ça dépend de votre utilisation. Si c'est pour ne jamais l'utiliser à volume modéré, alors ça semble vraiment être un excellent produit que je recommanderais.
ps. j'ai testé l'ampli en USB (avant de me rétracter et de le renvoyer pour le bruit de fond)
Tres bien, Mais !
Génial comme petit ampli
fonctionne a merveille avec des Tannoy pbm8
livraison rapide, mais pas le bonne COULEUR :(
Enfin rien de bien dramatique
