FX-AUDIO D802C Bluetooth 3.0 FDA Amplifier STA326 Class D 2x50W 8 Ohm Silver
4.9 / 5
Reference : 10675
145,00 €tax incl.
120,84 € tax excl.
Including 1,00 € for green tax
A fully-featured, class D STA326 Bluetooth amplifier with remote control, the FX-AUDIO D802C silver finish integrates a 24bit 192kHz analog digital converter with an AKM AK4113 S / PDIF interface, a Wolfson WM88782S ADC and a VIA VT1630A Audio / DSP interface.
This amplifier has the characteristic of being a "Full Digital", ie the S / PDIF signal is converted into I2s by the AK4113 and then directly amplified by the STA326.
In addition, it comes equipped with a Bluetooth 3.0 receiver module (CSR57E6) and a stereo RCA auxiliary input.
Its USB Audio jack is also OTG compatible. So you can plug in an Android smartphone.
It has three digital inputs (USB, S / PDIF coaxial and Toslink optics).
Its OLED display displays in real time the source used as well as the sampling rate of the audio file being played.
This all-in-one amplifier is also equipped with a digital equalizer with many functions (bass, treble, etc ...) adjustable directly from the remote control.
hewill prove to be the ideal companion for any digital source.
Hisergonomics and compactness are notable advantages, plus its versatility.
Features:br>
  • S & PDIF Interface AKM AK4113
  • Audio Controller / DSP VIA VT 1630A
  • ADC Wolfson WM8782S (24bit 192kHz)
  • OLED Screen
  • Displaying sampling rate
  • Wireless reception via Bluetooth 3.0 (CSR57E6)
  • STA326 amplifier module: 2 x 80W at 4 Ohm, 2x 50W at 8 Ohm
  • Filter Capacitors Nichicon 5400μF x3, WIMA x2
  • High-precision clock
  • Signal to Noise Ratio (SNR): 100dB
  • Frequency Response: 18Hz - 22kHz
  • Digital Equalizer
  • Supplied remote control or rotary encoder
  • Inputs: S / PDIF Optical Toslink, Coaxial and USB-B), stereo analog RCA
  • HP Outputs: On Terminal Blockits screwing supporting the banana plugs 4mm
  • Power supply 32V 5A included (5.5 / 2.5 jack connector)
  • Dimensions: 190x115x39mm
  • Weight: 700 g
  • USB-A to USB-B cable, remote control, 5dB Bluetooth antenna and power supply
  • Remote control CR2032 batteries not included
  • Direct (or Tone, or HiFi) mode, allows you to bypass the internal DSP, and amplify the live signal without modifications.
Channel
  • 2 (Stereo)
Download
7 reviews
Très bien
Si petit et si performant ! impeccable.
This review has been posted for FX-AUDIO D802C Bluetooth 3.0 FDA Amplifier STA326 Class D 2x50W 8 Ohm Silver
Extraordinaire rapport Q/Prix
Il faut l'écouter pour le croire: la HIFI (en terme de fidélité, pas de recherche de certains sons) traditionnelle n'a qu'à bien se tenir !!!
Incroyable performance pour ce minuscule ampli
Reçu ce matin, branché sur une paire de petites quad 9l2, pour la chambre de mon fils,
Résultat bluffant, image stéréo 3D, beaucoup de détail, relief, grande dynamique,
Excelle sur du jazz comme de l’electro, les voies sont très présentes et charnelles.... les basses étonnamment tendues’ rapides et profondes...
Le haut est parfois un peu dure, par rapport à du haut de gamme, mais là je chipote...
Bref, pour 130 €, j’imaginais pas un tel rendu.... (pour info mon système de référence est un sytème thdg à base de krell et panneaux magnepan A un tarif...),
Si vous hésitez en vous posant la question’ de la qualité sonore, ne vous la posez pas, c’est du tout bon.... et même plus
Cordialement
Patrice
Top et prix imbattable!!
Son bonne qualité, Bluetooth ultra réactif...
Erreur lors de la reception de la commande
J ai reçu un FX Audio D802 à la place d'un FX Audio 802C
Le SAV a rapidement réagi et j 'espère recevoir la bonne commande rapidement
