SMSL Q5 PRO FDA Amplifier TAS5342 2x45W + Subwoofer output / 4 Ohm CS5341 SA9023 Black
4.8 / 5
Reference : 10337
115,00 €tax incl.
95,83 € tax excl.
With a Cirrus Logic CS5341 converter and an SA9023 embedded USB interface, the SMSL Q5 Pro (latest revision by the manufacturer) is a particularly gifted amplifier.
It integrates a Texas Instruments TAS5508 + TAS5342 amplifier module delivering 2x 45W at 4 Ohms and 2x 25W at 8 Ohms.
This pro version now includes a Subwoofer output (SW OUTPUT) specially designed for subwoofers.
Versatile, it allows you to assign it 4 sources (stereo 3.5 jack, Coaxial S/PDIF, Toslink Optics and Micro USB).
It has a digital display and a remote control for easy control.
Its internal architecture as well as the choice of materials and finishes are all assets that make the Q5 a particularly efficient amplifier suitable for a wide range of configurations.
SMSL Q5 Pro review by Qobuz
" It must be recognized that this full digital amplifier S.M.S.L.Q5 pro provides, with a really small footprint and low calorie emission, sound results that can satisfy demanding amateurs, including us. A very surprising technology. "
Test Qobuz
Characteristics :
  • Cirrus Logic CS5341 Converter
  • Texas Instruments Digital Amplifiers TAS5508 + TAS5342
  • S/PDIF Cirrus Logic CS8422 S/PDIF interface
  • Asynchronous USB interface SA9023
  • Support for files up to 24bit 96kHz (USB) and 24bit 192kHz (S/PDIF)
  • Max. power output 2x 25W under 8 Ohm, 2x 45W under 4 Ohm
  • Frequency response: 20Hz - 22kHz to +/- 3dB
  • Signal-to-noise ratio: 81dB
  • Dynamic range 102dB
  • THD+N : 0.05%.
  • Inputs : 3.5 stereo jack, Coaxial S/PDIF, Toslink optics, Micro USB
  • Hp terminal block output accepting banana plugs
  • Subwoofer output filtered at 100Hz
  • Volume control
  • On/Off switch
  • Max. consumption : 102W
  • Frame Aluminium frame CNC machined anodized Black
  • Front Anodized Black Aluminium Front
  • Dimensions: 137x103x33mm
  • Weight: 1.1kg
  • Power supply (19V 6.3A jack 2.5 / 5.5), remote control (battery not included) and Micro USB cable included
  • Android 4.0 and higher compatible in USB OTG
InputJack 3.5mm
OutputSubwoofer
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTAS5508
Power (W)25.0
19 reviews
Avec des Triangle Lymna Plaisir le son est de haute qualité
Avec des Triangle Lymna Plaisir 90db le son est de haute qualité
J'ai un caisson de basse Canton 50/100w 85db
Et le tout s'exprime sans rien en retrait
La connectique est génial ainsi que la télécommande
L'USB est reconnu en plug and play
J'aime le réglage de la tonalité aigu et basse avec en plus des réglages prédéfinis
le seul point négatif est qu'il ne s'éteint pas automatiquement en cas d'oubli
This review has been posted for SMSL Q5 PRO FDA Amplifier TAS5342 2x45W + Subwoofer output / 4 Ohm CS5341 SA9023 Black
SMSM Q5 Pro
J'avais besoin d'un deuxième ampli, j'hésitais entre le SMSL Q5 pro et le FX audio 802C que j'avais déjà et que j'utilise dans le salon pour la TV et la musique. Je ne regrette pas mon choix. J'utilise le Q5 pro comme ampli pour le PC avec 2 bonnes enceintes. La qualité du son est exceptionnelle même à faible volume. Très bon rapport qualité/prix. Autre chose qui a aussi une importance, la qualité de service et les prix d'audiophonic !
Essai en Salle de Ventes
https://youtu.be/wd8X0BbhrvY
Bonne surprise!!
Bonjour tout le monde ! je suis tres satisfait du site "audiophonics.fr"renseignements demandés par mail ,reponse precise et rapide,livraison rapide( 2 jours)un site comme j' aime
Concernant cet ampli fda, sur divers forum,j'en avais lu que du bien,mais je voulais constater avec ma propre ecoute;et je ne suis pas deçu ! avant tout;je cherchais un systeme efficace mais,surtout compact,pour installer sur mon bureau; me permettant d'ecouter mes cd preférés,avec un son correct,je ne suis pas un puriste audiophile,loin de là,mais j'apprecie quand meme un certain confort d'ecoute ,il me faut mieux qu'un systeme d'ecoute multi media,( etant musicien,j'aime quand meme le bon son )et bien avec cet ampli là,cela correspond tout à fait à mes attentes,je possede une vieille paire d'enceintes jm lab " tantal en tres bon etat ,couplées avec une vieille platine cd technics, reliée avec un cable coax de 75 ohms sur l'ampli;le tout combiné,me satisfait amplement,j'ai un son ,plus que correct, le son et assez equilibré,et il y a un bon rendu sonore,je m'attendais à quelque chose de beaucoup plus froid;mais non,on a un rendu qu'on pourrait avoir avec pleins d'autres amplis hi-fi de diverses marques;pour vraiement sentir la dynamique il faut un peu pousser le volume ,mais dans une piece de 12m²,je ne peux pas,mais je sent qu'il y a de la marge,
où, cet ampli m'impressione vraiement ,c'est au niveau de sa petite taille ! mais il m' a fallu quand meme un petit temps d'adaptation pour habituer mes oreilles,car ,dès la 1ere ecoute ,j'ai eu, une drole de sensation,que je n'arrive pas à decrire avec des mots,pas un son agressif,mais ça me faisait bizzarre,mais au bout d'une 20 aine de minute,mes oreilles se sont habituées;car j'utilisais ma platine et mes enceintes avec un ampli home cinema yamaha,qui me convenait tres bien, mais trop encombrant sur mon bureau; je cherche vraiement à compactiser au maximum mon systeme d'ecoute,d'ailleurs ,sur le site il y a une platine cd "shanling-tempo"qui m'a l'air bien sympa,encore un peu trop encombrante à mon gout,il y a bien sure, d'autres platines cd beaucoup plus petites mais beaucoup plus couteuses,en conclusion ,si vous rechercher un micro ampli qui sonne ma foi,plutot bien à un prix vraiement sympa,n'hesitez pas,maintenant,est ce un produit qui va durer dans le temps ?on verra,bien ; en tous cas,je suis tres agreablement surpris et satisfait par ce petit ampli,je vous le conseille fortement.,rapport prix, encombrement,performances,c'est top !
christian N
Bluffant
Très favorablement surpris dès la première écoute. Mérite d'être découvert
