FURUTECH TF Rhodium Plated OFC Copper Fuse Type T Slow 5x20mm 0.5A
With its TF range, Furutech offers exceptional semi-slow time delay fuses. Indeed, the brand integrates very high quality components to maximise the performance of the fuse and thus not to degrade the quality of the signal passing through it, each step in the signal path being as important as the previous and following ones.
3.0 / 5
Reference : 12229
50,90 €tax incl.
42,42 € tax excl.
Furutech TF
Furutech TF Fusible Cuivre OFC Plaqué Rhodium Type T Lent 5x20mm 0.5A
Thus, each material of this fuse is carefully selected and processed. The ends are made of rhodium-plated OFC copper with a low inductance copper alloy conductor and the body is made of ceramic with a damping filling. Each metal part is treated using the Alpha process, consisting first of cryogenisation of the material to consolidate its molecular structure and thus improve its conductivity, and then subjecting it to a strong magnetic field to leave no magnetic residue (anti-magnetism).
This is the 5x20mm 0.5A fuse, sold individually.
Product typeFuse
Current0.5A
TypeType T (Slow)
Dimensions5 x 20mm
Material of the tipsRhodium plated OFC Copper
Conductor materialLow inductance Copper alloy
Body materialCeramic
TreatmentFurutech Alpha
QuantitySold individually
Plus de transparence et de précision mais...
Comme tous les fusibles audiophiles, l'apport en transparence ou précision est réel et bienvenu mais dans le cas de ce Furutech, essayé sur un lecteur CD HDG ou un ampli-préampli HDG, la musicalité est moindre qu'avec le fusible d'origine (évidemment essayé dans les deux sens !). Cela dit, je suis convaincu maintenant qu'un fusible Furutech apportera beaucoup à de très nombreux systèmes par rapport au fusible d'origine. J'hésitai donc entre trois et quatre étoiles.
This review has been posted for FURUTECH TF Rhodium Plated OFC Copper Fuse Type T Slow 5x20mm 0.5A
With its TF range, Furutech offers exceptional semi-slow time delay fuses. Indeed, the brand integrates very high quality components to maximise...
