Fuse Furutech TF Copper OFC plated Rhodium Type T Slow 5x20mm 5A
Furutech offers, with its TF range, exceptional semi-slow timed fuses. Indeed, the brand incorporates high-quality components to maximize the performance of the fuse and thus not degrade the quality of the signal passing through it, each step in the signal path being as important as the previous ones or the following ones.
Thus, each material of this fuse is carefully selected and worked. The ends are OFC Copper plated Rhodium with a low-inductance copper alloy conductor and ceramic body with a damping filling. Each metal part is processed by the Alpha process, which consists firstly in cryogenizing the material to consolidate its molecular structure and thus to improve its conductivity and then subjecting it to a strong magnetic field in order to leave no magnetic residue -magnetism).
This is the fuse in 5x20mm 5A, sold by the unit.
TECHNICAL CHARACTERISTICS
- Current Rating: 5A
- Type T (Slow)
- Dimensions: 5x20mm
- Material end: Copper OFC plated Rhodium
- Conductor Material: Copper Alloy Low Inductance
- Body Material: Ceramic
- Treatment: Furutech Alpha
- Sold individually
