EIZZ EZ-901 Fuse Holder Silver Plated 5x20mm 250V 15A
This high quality 5x20mm Eizz EZ-901 fuse holder uses silver plated contacts, ensuring excellent conductivity and durability. Its spring-loaded center pin promotes optimal contact.
Reference : 17507
35,90 €tax incl.
29,92 € tax excl.
Eizz EZ-901
Fuse Holder Silver-plated 5x20mm 250V 15A
Eizz EZ-901 Porte fusible plaqué rhodium 5x20mm 250V 15A
This high quality 5x20mm Eizz EZ-901 fuse holder uses silver-plated contacts, ensuring excellent conductivity and durability. Its spring-loaded center pin promotes optimal contact. Moreover, the fuse holder allows a quick and easy mounting on panels up to 20mm thick.
Product typeFuse holder
Contacts platingSilver
Fuse holder dimensions5x20mm
Voltage / Current250V 15A
Max panel thickness20mm
Total dimensionsØ19.8*47.7mm
Rated current (A)15.0
Qualité !
Très bonne qualité que ce porte fusible : remplacé sur mon parasound A21, le diamètre est parfaitement adapté la soudure en périphérie se fait sans difficulté majeur. L'isolant central blanc est en téflon donc sans déformation au moment de la soudure. Quand on utilise un fusible de qualité (comme pour moi) il est a mon avis plus que souhaitable d'avoir le porte fusible en conséquence.
This review has been posted for EIZZ EZ-901 Fuse Holder Silver Plated 5x20mm 250V 15A
This high quality 5x20mm Eizz EZ-901 fuse holder uses silver plated contacts, ensuring excellent conductivity and durability. Its...
