Fuse Holder on Wire 5x20mm 10A
Reference : 13011
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 16-04-2025.
Fuse wire Audiophonics 10A 250V
Fuse holder 5x20mm PTFE sheath
This fuse holder is designed to work with 5x20mm fuses. It comes with a fuse 10A 250V.
The cables are already mounted with their fuse connector. They are very resistant and benefit from a sheath in very heat resistant PTFE, fire, moisture, corrosion.
TypeFuse holder on wire
Fuse5 x 20 mm
Max amperage10A
Tension max250V
Fuse typeGlass
Operating temperature-60°C / + 200°C
Cabletinned copper conductor 19 x 0.26 mm
Overall Diameter: 2 mm
Conductor cross-sectionnal area : 1 mm²
Length: 150 mm (non-naked)
Sheath PTFE (Teflon)
Item deliverySelf-assembly (unmounted) / 1 Fuse 250V/10A Included
Rated current (A)10.0
