Fuse Holder on Wire 5x20mm 15A
4.0 / 5
Reference : 13010
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 22-04-2025.
Fuse wire Audiophonics 10A 250V
Fuse holder 5x20mm PTFE sheath
This fuse holder is designed to work with 5x20mm fuses. It comes with a fuse 10A 250V.
The cables are already mounted with their fuse connector. They are very resistant and benefit from a sheath in very heat resistant PTFE, fire, moisture, corrosion.
TypeFuse holder on wire
Fuse 5 x 20 mm
Max amperage15A
type fuseGlass
Operating temperature-60°C / + 200°C
Cabletinned copper conductor 19 x 0.37 mm
Diameter: 2.5 mm
Conductor cross sectionnal area : 2mm²
Length: 160 mm (non-naked)
Sheath PTFE (Teflon)
Item deliverySelf-assembly (unmounted) / 1 fuse 250V / 10A included
Rated current (A)15.0
Câble un peu trop rigide
Fait le job.
This review has been posted for Fuse Holder on Wire 5x20mm 15A
