ELECAUDIO GC-0104 Braided shielding sheath 100% Copper 1-4mm
4.8 / 5
Reference : 3347
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 29-04-2025.
Gaine vendue au mètre
The braided tinned copper sheath is reputed to protect against Electro Magnetic Interference (EMI).
They are used extensively to reinforce shielded or replacement cables to protection problems arising from data loss or signal interference.
Thes Cu / Sn braided sheaths provide an attenuation of more than 60 dB in high frequency, from a few kiloherts (kHz) to several gigahertz (gHz).
The Gbraided wires offer greater flexibility over film-coated cables.
(Sold by the meter)
Depending on the diameter of the cable to be sheathed, the effective sheath length can be reduced by up to 30%. We therefore recommend that you order a sheath length at least 30% longer than the length of your cable.
Features:
  • 100% tin plated copper
  • Diameter 1 to 4mm
  • Electrostatic and electromagnetic protection
  • Electrical noise attenuation
  • Improved resistance to abrasion and cuts compared to thermoplastic braided sheaths.
  • Better protection against Radio Frequency Interference (PRE) between 0.5 MHz and 1.7 MHz.
  • EMI / RFI protection
  • Better flexibility
  • Tinned copper wire braid 36AWG
  • Coverage of 85-90% nominal diameter
ColorChampagne
MaterialCopper
Length (m)Sold by length
Max cable diameter (mm)4.0
4 reviews
Conforme à la description.
Utilisée pour fabriquer un blindage sur un câble d'alimentation secteur d'un téléviseur.
This review has been posted for ELECAUDIO GC-0104 Braided shielding sheath 100% Copper 1-4mm
Très pratique
Pour des montages sans bruit parasite.
Satisfait
Produit conforme, reçu rapidement
Buona qualità
sono ottime, molto schermanti e pesanti. Ma le avrei preferite placcate in argento.
