HIFI 2000 Galaxy GX283 Chassis 10mm 80x230x230 Black
Reference : 5382
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 25-04-2025.
Aluminum Housing 210 x 230 x 80 Front face 10 mm Black
GX283 Boitier HiFi2000
This HIFI 2000 housing Galaxy GX283 entirely aluminum is a great solution for your DIY projects.
Elegant and long-lasting, it provides excellent protection for your device electronic components. It has air holes on its top cover to allow the air to circulate and dissipate the heat. The GALAXY serie by HIFI 2000 counts small and medium-sized housings which are ideal for active filters, preamplifiers...etc.
Internal Dimensions
DimensionsHeightLengthWidth
Internal80210230
External84230241
Parts
TypeSelf-Assembly Housing
Front faceAluminum
10mm thick
Back faceAluminum
3mm thick
Side coversAluminum extruded
10mm thick
Top & bottom coversSteel 2mm
Weight1.9 kg
MaterialAluminium
Internal width210
Internal depth230
Internal height80
Façade trop épaisse ATTENTION !
Boitier intéressant mais quais inutilisable.... La façade de 1cm d'épaisseur empêche l'installation de la majorité des interrupteur et led dont la majorité des pas de vis font moins de 1cm...
D'autre part, le montage du capot est absolument fastidieux, il faut aligner 4 écrous au mm pour pouvoir la visser : ils font de bons yeux..... Made in Italy mais au final, mes boîtiers chinois font mieux )
This review has been posted for HIFI 2000 Galaxy GX283 Chassis 10mm 80x230x230 Black
