HIFI2000 GX388 - 80x330x280 - Facade 10mm Noire
The Galaxy models are small housings particularly suitable for mounting active filters, preamplifiers, etc.... The internal useful height is 80mm.
4.5 / 5
Reference : 5387
95,00 €tax incl.
79,17 € tax excl.
HIFI 2000 Galaxy GX388
Aluminum Housing 310 x 280 x 80 Front face 10 mm Black
GX388 Boitier HiFi2000
This HIFI 2000 housing Galaxy GX388 entirely aluminum is a great solution for your DIY projects.
Elegant and long-lasting, it provides excellent protection for your device electronic components. It has air holes on its top cover to allow the air to circulate and dissipate the heat. The GALAXY serie by HIFI 2000 counts small and medium-sized housings which are ideal for active filters, preamplifiers...etc.
Internal Dimensions
DimensionsHeightLengthWidth
Internal80310280
External84330291
Parts
TypeSelf-Assembly Housing
Front faceAluminum
10mm thick
Back faceAluminum
3mm thick
Side coversAluminum extruded
10mm thick
Top & bottom coversSteel 2mm
Weight2.6 kg
MaterialAluminium
Internal width310
Internal depth280
Internal height80
2 reviews
Produit de qualité.
Même sans notice c'est facile à assembler.
Il manque quand même quelques zones non serrables ce qui fait que mon transfo torique de plusieurs kilos fait plier la plaque de support basse. Pas le choix que de placer des cônes juste sous les points d'appui de la charge (transfo) alors que je voulais les placer aux extrémités.
La continuité électrique se fait bien entre chaque face en ne mettant qu'une seule d'entre elle à la terre.
This review has been posted for HIFI2000 GX388 - 80x330x280 - Facade 10mm Noire
Solid product
When assembling this case I could feel it solid, sturdy and elegant
It makes you feel like you invested money in a very high quality product. 100% recommended
