HIFI 2000 GALAXY GX147 Aluminium Case 124 x 170 x 40mm 3mm Front Panel Silver
This HIFI 2000 Galaxy GX147 all-aluminium case will allow you to create and dress your DIY creations. Strong, it will prove to be durable and will perfectly protect all the components of your device.
4.5 / 5
Reference : 1117
35,90 €tax incl.
29,92 € tax excl.
Shipping date: 25-04-2025.
Aluminum Housing 104 x 170 x 40 Front face 3 mm Silver
GX147 Boitier HiFi2000
This HIFI 2000 housing Galaxy GX147 entirely aluminum is a great solution for your DIY projects.
Elegant and long-lasting, it provides excellent protection for your device electronic components. It has air holes on its top cover to allow the air to circulate and dissipate the heat. The GALAXY serie by HIFI 2000 counts small and medium-sized housings which are ideal for active filters, preamplifiers...etc.
Internal Dimensions
DimensionsHeightLengthWidth
Internal40104170
External42124176
Parts
TypeSelf-Assembly Housing
Front faceAluminum
3mm thick
Back faceAluminum
3mm thick
Side coversAluminum extruded
10mm thick
Top & bottom coversSteel 2mm
Weight0.7 kg
ColorSilver
MaterialAluminium
Internal width104
Internal depth170
Internal height40
2 reviews
Fait le job
Fait le job mais jour de presque 1mm entre la façade avant et la façade supérieur/inférieur. Découpes des façades avant/arrière assez moyennes via cisaillement. Finition brossée sur ces façades - Beau rendu global mais il ne faut pas allé dans le détail.
Utilisé pour monter une alim SMPS 300RS 24V pour un petit ampli FDA.
This review has been posted for HIFI 2000 GALAXY GX147 Aluminium Case 124 x 170 x 40mm 3mm Front Panel Silver
Montage très facile et finitions irréprochables. Façades indépendantes du reste du boitier, et peuvent être rapidement dévissées sans toucher au reste du boitier, de même pour le fond et/ou le couvercle.
This HIFI 2000 Galaxy GX147 all-aluminium case will allow you to create and dress your DIY creations. Strong, it will prove to be durable and will...
