Hifi 2000 Galaxy GX283 Chassis 3mm 80x230x230
4.4 / 5
Reference : 1125
42,90 €tax incl.
35,75 € tax excl.
Shipping date: 24-04-2025.
HIFI 2000 Galaxy GX283
Aluminum Housing 210 x 230 x 80 Front face 3 mm Silver
GX283 Boitier HiFi2000
This HIFI 2000 housing Galaxy GX283 entirely aluminum is a great solution for your DIY projects.
Elegant and long-lasting, it provides excellent protection for your device electronic components. It has air holes on its top cover to allow the air to circulate and dissipate the heat. The GALAXY serie by HIFI 2000 counts small and medium-sized housings which are ideal for active filters, preamplifiers...etc.
Internal Dimensions
DimensionsHeightLengthWidth
Internal80210230
External82230233
Parts
TypeSelf-Assembly Housing
Front faceAluminum
3mm thick
Back faceAluminum
3mm thick
Side coversAluminum extruded
10mm thick
Top & bottom coversSteel 2mm
Weight1.9 kg
ColorSilver
MaterialAluminium
Internal width210
Internal depth230
Internal height80
7 reviews
Very happy
Everything in order, well built, solid and easy to assemble
This review has been posted for Hifi 2000 Galaxy GX283 Chassis 3mm 80x230x230
Very happy
The product is exactly as described, it is really well designed and well built, everything was perfect.
Pas ouf
Assez déçu par ce boitier dont le système de fixation des capot est mal conçu selon moi. De plus, les petites vis de fixation sont trop courtes pour atteindre l' écrou dans la rainuré. Y' a mieux.
good quality box
good quality box
Très bien
Bon boitier et pas cher. Mine de rien c'est un boitier radiateur très discret et pratique pour tourner un petit ampli classe B ou bien tout montage qui a besoin de dissipation. Je fais tourner un Ampli LJ L7 dessus et ça va très bien.
