Hifi2000 - Galaxy GX183 80x124x230
4.0 / 5
Reference : 3090
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 25-04-2025.
HIFI 2000 Galaxy GX183
Aluminum Housing 104 x 230 x 80 Front face 3 mm Silver
GX183 Boitier HiFi2000
This HIFI 2000 housing Galaxy GX183 entirely aluminum is a great solution for your DIY projects.
Elegant and long-lasting, it provides excellent protection for your device electronic components. It has air holes on its top cover to allow the air to circulate and dissipate the heat. The GALAXY serie by HIFI 2000 counts small and medium-sized housings which are ideal for active filters, preamplifiers...etc.
Internal Dimensions
DimensionsHeightLengthWidth
Internal80104230
External82124236
Parts
TypeSelf-Assembly Housing
Front faceAluminum
3mm thick
Back faceAluminum
3mm thick
Side coversAluminum extruded
10mm thick
Top & bottom coversSteel 2mm
Weight1.2 kg
ColorSilver
MaterialAluminium
Internal width104
Internal depth230
Internal height80
4 reviews
Super qualité prix!
Facile à monter, ne fait pas cheap malgré une face de seulement 3mm.
Les vis ne sont pas trop courtes, ce sont les trous qui ne sont pas suffisamment chanfreinés. Apres un coup de fraise les vis sont à fleur.
This review has been posted for Hifi2000 - Galaxy GX183 80x124x230
Pourrait mieux faire
Pour une question de vis trop courtes.
En effet les 8 vis 3 mm tête fraisée du capot et du dessous ne prennent que quelques tours sur les écrous noyés et si on serre trop fort, ça foire. J'ai du commander des vis 2 mm plus longues. Dommage, car ce coffret est bien fini.
Nice looking box on a budget
On the plus side the box once assembled looks good for a relatively budget box and is performing the job I required.
On the negative side the small bolts that are used attach the base and the top plate to the side plates are very short and only just catch the nuts they screw into, they are effectively one shot use. If you need to remove the top plate to gain access after assembly the bolts will be scrap and need replacing, fortunately there are some spare bolts in the kit I had.
Another negative is that there is no electrical continuity between the components which if you intend to put mains voltages in the box is potentially dangerous. As I was constructing a power supply one of the main components was a transformer from 240v to 12v so this was an issue for me. To get continuity I had to remove the paint from all the jointing faces in order to get an electrical continuity and enable the box to be earthed, not ideal.
Well made, massive and stable case
I bought this case to hold a class-A power supply together with my Hifiberry DAC. They tightly fit in. The case is stable and it's easy to drill the holes to mount the parts into it, as every side can be unmounted.
The case is a good deal for its price.
