Monacor SP-6 / 108PRO Speaker Driver Midbass 100W 8 Ohm 92dB 44Hz - 4500Hz Ø16.5cm
Reference : 5803
89,00 €tax incl.
74,17 € tax excl.
Compact Bass Loudspeaker, 150 W MAX, 100 WRMS, 8 Ω
For years appearing in the high-end categories of professional speakers of IMG Stage Line (series 500); now they are also available individually. The 30 cm (12 ") and 38 cm (15") shine with perfectly attenuated transmission behavior down to the medium range.high and allow extremely clean sounds, the 16cm bass-midrange speaker makes the Hi-Fi sound suitable for the stage.
  • 16.5 cm (6.5 ") Professional Hi-Fi Professional Bass-Loudspeaker
  • Carbon fiber membrane
  • Exceptional sound and dynamic properties
  • Coil with inner and outer coil for optimum heat release
  • Very low distortion bandwidth with very low efficiency
  • Excellent combined with the DT-300 et to WG-300
  • Ideal for small sound systems and sounder zones
  • Recommended in Hi-Fi and monitor applications
https://www.audiophonics.fr/images2/5803/5803_SP-6-108PRO_1.jpg
https://www.audiophonics.fr/images2/5803/5803_SP-6-108PRO_4.jpg
https://www.audiophonics.fr/images2/5803/5803_SP-6-108PRO_2.jpg
https://www.audiophonics.fr/images2/5803/5803_SP-6-108PRO_3.jpg
Speaker Power (W RMS)100.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)100.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)92.0
Max Linear Excursion (Xmax) (mm)3.0
Lowest frequency (Hz)44
Highest frequency (Hz)4500
Superbe et Efficace
Très BON bas médium , j'en ai couplé 4 avec 2 tweeter Monacor DTM-104/8 pour refaire à neuf mes 2 enceintes de salon = Très Satisfait du SON Obtenu
This review has been posted for Monacor SP-6 / 108PRO Speaker Driver Midbass 100W 8 Ohm 92dB 44Hz - 4500Hz Ø16.5cm
