This standard Dayton Audio DCS380-4 subwoofer is ideal as a replacement for an HS subwoofer of the same size or for creating a subwoofer.
Strengths:
Subwoofer 4Ω ⌀38.1cm 250W RMS
The DCS380-4 is a standard subwoofer speaker that will be suitable for most systems, replacing an HS subwoofer of the same size or simply for creating a new subwoofer. For maximum versatility, this speaker has been designed to be suitable for both bass reflex and closed speakers. The very robust diaphragm and the large suspensions ensure a high linear excursion for excellent performance in low frequencies.
Speaker type | Subwoofer |
Nominal diameter | 38.1cm (15") |
Diaphragm material | Paper cone |
Magnet material | Ferrite |
Voice coil wire material | Copper |
Overall outside diameter | 385mm |
Depth | 186mm |
Power handling | RMS : 250W MAX : 500W |
Impedance | 4Ω |
Sensitivity | 93.6dB @ 2.83V/1m |
Frequency response | 20Hz - 500Hz |
DC Resistance (Re) | 2.9Ω |
Voice coil inductance (Le) | 2.31mH @ 1kHz |
Resonant frequency (Fs) | 21.5Hz |
Mechanical Q (Qms) | 3.79 |
Electromagnetic Q (Qes) | 0.49 |
Total Q (Qts) | 0.44 |
Diaphragm Mass Inc. Airload (Mms) | 190g |
Mechanical compliance of suspension (Cms) | 0.29 mm/N |
Surface area of cone (Sd) | 819.4cm² |
Volume of displacement (Vd) | 688.3cm² |
Maximum linear excursion (Xmax) | 8.4mm |
Sealed Volume | 108.74 Litres |
Sealed F3 | 40 Hz |
Vented Volume | 361.61 Litres |
Vented F3 | 21 Hz |
