DAYTON AUDIO LS12-44 Speaker Driver Low Profile Subwoofer Dual Coil 250W 2x4 Ohm 88dB 28Hz - 300Hz Ø30.5cm
DAYTON AUDIO LS12-44 Low Profile 12" Subwoofer Dual Coil 4 Ohm
This 12 "Dayton Audio LS12-44 low profile subwoofer allows integration into tight spaces, while providing deep bass.
Reference : 12541
175,00 €tax incl.
145,83 € tax excl.
Shipping date: 27-09-2024.
Low Profile Subwoofer 12" Dual Coil
dayton audio ls12-44
With a depth of only 10.2cm (4 ") this LS12-44 Subwoofer from Dayton Audio has a low profile design that allows for integration into spaces that would not fit most subwoofers, such as in a ceiling or walls.
In addition, this 12 "Subwoofer has a quality design with a double ceramic ferrite coil allowing 2 or 8Ω wiring and a flat aluminum and fiberglass membrane allowing a 10mm excursion for deep bass. With its two thick aluminum rings is optimized for symmetrical movements, reducing distortion and achieving striking bass.
Nominal diameter12" (304.8mm)
Power Handling RMS250W
Power Handling Max500W
Impedance4Ω + 4Ω
Frequency response28 to 300Hz
Sensitivity88dB 2.83V/1m
Voice coil diameter2" (50.8mm)
Resonant frequency (Fs)33.7Hz
DC Resistance (Re)7.5Ω
Voice coil inductance (Le)5.34mH
Mechanical Q (Qms)4.94
Electromagnetic Q (Qes)0.56
Total Q (Qts)0.51
Compliance of suspension (Cms)0.13mm/N
BL Product (Bl)21.7Tm
Diaphragm Mass Inc. Airload (Mms)166g
Maximum linear excursion (Xmax)10mm
Surface area of cone (Sd)547.3cm²
Materials
Cone materialFiberglass
Surround materialRubber
Basket materialAluminium
Magnet materialFerrite
Mounting informations
Overall outside diameter12.375" (314.33mm)
Baffle cutout diameter11.125" (282.58mm)
Depth4" (101.6mm)
Mounting holes8
Weight4.99kg
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume36.81 Litres
Sealed F353 Hz
Vented Volume84.95 Litres
Vented F329 Hz
Speaker Power (W RMS)250.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)305.0
Diaphragm typeGlass fiber
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)10.0
Lowest frequency (Hz)28
Highest frequency (Hz)300
Très bon produit
J'ai remplacé un SP300 un peu âgé dans un caisson de basse.
La différence est impressionnante, des basses très claires, précises et bien présentes.
This review has been posted for DAYTON AUDIO LS12-44 Speaker Driver Low Profile Subwoofer Dual Coil 250W 2x4 Ohm 88dB 28Hz - 300Hz Ø30.5cm
