DAYTON AUDIO UM15-22 Ultimax DVC Speaker Driver Subwoofer 800W 2x2 Ohm 87dB 15Hz - 1000Hz Ø38cm
DAYTON AUDIO UM15-22 Ultimax DVC Subwoofer Speaker 2+2 Ohm Ø38cm
The Ultimax range of double coil subwoofers from Dayton Audio is the guarantee of powerful bass. Designed using the latest subwoofer technology, the Ultimax is the ultimate low frequency driver for dynamic, accurate and deep bass.
By buying this product you get 35 loyalty points
Reference : 13036
359,00 €tax incl.
299,17 € tax excl.
Dayton Audio UM15-22 Ultimax Subwoofer
Powerful bass
A polyvalent HP
The Double 2 Ohm coils allow the use of 2 Ohm stereo or 1 Ohm mono configurations for high current connection in Car Audio or on professional amplifiers to extract maximum power. For home use, 4 Ohm wiring is preferred for greater compatibility with amplifiers.
Designed to produce massive low frequencies
To improve power support, thermal management, and reduce compression, Dayton Audio designed the Ultimax range with an anodized structure, open polarized parts, ventilation under the spider, and double layer coils.
The UM15-22 offers a linear excursion (Xmax) of 19mm totally linear thanks to the use of a double spider, also limiting distortion. The rubber suspension with integrated gaskets maintains the diaphragm surface in moments of high travel. Nomex honeycomb diaphragms are covered with high-strength, woven fiberglass that allows the diaphragm to resist deformation.
A powerful motor to sublimate your music
In the motor, a copper strapping and a copper pole cover also reduce the energy storage of the inductance, with another positive effect of reducing distortion for a faster response. The two very powerful stacked magnets push the Qts (Total Quality Coefficient) to a level that allows the Ultimax to be used in open or closed boxes.
Speaker typeSubwoofer
Nominal diameter38.1cm (15")
Power handlingRMS : 800W
Max : 1600W
Impedance4 Ohm
Frequency response15Hz - 1000Hz
Sensitivity86.5dB 2.83V/1m
Voice coil diameter6.35cm (2.5")
Measurements
Resonant frequency (Fs)19.5Hz
DC Resistance (Re)3.4 Ohm
Voice coil inductance (Le)1.31mH
Mechanical Q (Qms)2.40
Electromagnetic Q (Qes)0.59
Total Q (Qts)0.47
Compliance equivalent volume (Vas)7.92ft.³
Mechanical compliance of suspension (Cms)0.24mm/N
BL Product (BL)15.4Tm
Diaphragm mass inc. airload (Mms)279.4g
Maximum linear excursion (Xmax)19mm
Surface area of cone (Sd)814.6cm²
Materials
Cone amterialNomex / Glass fiber
Surround materialRubber
Voice coil wire materialCopper
Voice coil formerAluminium
Basket materialCasr Aluminium
Magnet materialFerrite
Mounting information
Overall outside diameter38.81cm (15.28")
Baffle cutout diameter35cm (13.78")
Depth19.2cm (7.55")
Bolt circle diameter37.2mm (14.65")
Mounting holes number8
Optimum cabinet size (détermined using BassBox 6 Pro)
Sealed volume3.98ft.³
Sealed F333Hz
Vented volume11.1ft.³
Vented F317Hz
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume112.70 Litres
Sealed F333 Hz
Vented Volume314.32 Litres
Vented F317 Hz
Speaker Power (W RMS)800.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)380.0
Diaphragm typeGlass fiber
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)19.0
Lowest frequency (Hz)15
Highest frequency (Hz)1000
2 reviews
Machine de guerre
Monte en clos de 90l avec un atohm s500 et un dspeaker c est démoniaque infernal. C est lourd pesant et massif sans etre traînant superbe en home cinéma et bénéfique meme en hifi
This review has been posted for DAYTON AUDIO UM15-22 Ultimax DVC Speaker Driver Subwoofer 800W 2x2 Ohm 87dB 15Hz - 1000Hz Ø38cm
The beast
Un monstre pas encore testé mais les perfs sont connues et appréciées de tous a mettre en volume clos et un bon caisson en devenir qui sera associé a petit atohm s500
The Ultimax range of double coil subwoofers from Dayton Audio is the guarantee of powerful bass. Designed using the latest subwoofer technology,...
