Audio Extractor HDMI 1 to 2 DTS Dolby HDCP2.3 HDR 4K 60Hz eARC CEC
With its high bandwidth and 18Gb/s digital data rate, this extractor is capable of working with 4K2K@60Hz HDCP 2.3, HDR 10bits streams and accepts a wide range of audio technologies.
Reference : 15583
59,90 €tax incl.
49,92 € tax excl.
Extracteur Audio HDMI
This compact and very complete HDMI extractor allows you to separate the audio and video signal from your digital HDMI source in order to send the image to your television and the sound to your home cinema decoder. The process preserves the original stream encoding and offers high resolution digital audio output available on HDMI connector as well as video output on HDMI connector supporting ARC / eARC feedback.
With its high bandwidth and digital throughput of 18Gb / s, this extractor is able to work with 4K2K @ 60Hz HDCP 2.3, HDR 10bits streams and accepts a wide range of audio technologies to ensure maximum compatibility with your storage media as well. as your installation: PCM 2.0, LPCM 5.1 / 7.1, Dolby Digital, Dolby Digital +, Dolby True HD, Dolby Atmos, DTS 5.1, DTS ES 6.1, DTS HRA, DTS HD Master, DTS: X.
There are 2 operating modes:
eARC activated: The stream is sent to the TV, then returns to eARC to the AVR amplifier on OUT2
The volume can be controlled by the TV, but the audio format is limited to the ARC or eARC capabilities of the TV.
eARC disabled: The TV still receives the stream, but the OUT2 output extracts the audio stream directly from the source.
The CEC is kept but the volume will be managed on the amplifier.
This allows you to play an audio format ex: DTS-HD MA on the AVR amplifier that the TV does not manage, while sending 4K HDR to the TV that the amplifier does not manage.
EDID:
Choice of the port used for the detection of the supported formats.
Ex: If the TV does not support DTS, EDID must be set to 2 for the source to detect the sound capabilities of the amplifier.
SPECIFICATIONS
HDMI protocolHDMI 2.0b, HDCP 2.3 / 1.x
Bandwidth18Gbps
Max resolution4K2K@60Hz 24bit RGB / YCBCR 4:4:4
VESA supportQSXGA@60hz
Encodages audio supportésPCM 2.0, LPCM 5.1 / 7.1, Dolby Digital, Dolby Digital +, Dolby True HD, Dolby Atmos, DTS 5.1, DTS ES 6.1, DTS HRA, DTS HD Master, DTS:X
Support eARC/ARCYes (TV to HDMI out)
Support CECYes
Support EDID ManagementYes
Input1x HDMI female
Output2 x HDMI female
Materialshousing : Aluminum
Dimensions65 x 70 x 27 mm
Weight83g
Power supplymicro USB 5VDC
Power consumption1.75W Max
Working temp0-40°C
ColorSilver
Packet content
1xHDMI audio extractor
1xUSB-A male to male micro-USB cable
InputHDMI
OutputHDMI
ColorSilver
2 reviews
Fait ce qu'on attend de lui
Appareil qui m'a permis de garder mon projecteur de son ysp 5600 en le couplant a une TV récente mais en intercalant un NVIDIA Shield.
Petite frayeur car impossible de décoder le dts x 24bits lorsque l'extracteur était en place mais problème résolu en passant la TV en bitsream
This review has been posted for Audio Extractor HDMI 1 to 2 DTS Dolby HDCP2.3 HDR 4K 60Hz eARC CEC
Très utile pour garder un ancien ampli HC
Si je ne fais pas erreur, il s'agit d'un FeinTech VAX01202 en marque blanche.
L'appareil m'a permis de profiter d'un Pioneer SC-LX87, génial mais limité en HDMI 1.4, dans mon installation qui a besoin du HDMI 2.0 pour la 4K et le HDR.
Je n'ai pas le eARC sur la TV, mais le principe serait le même : ne pas avoir à changer tout le matériel si une norme évolue.
Je l'ai mis à la sortie de ma box Android TV, puis il sépare l'audio, qu'il envoie à l'ampli, de la vidéo qu'il envoie à la TV.
Tout est détecté immédiatement, et je l'alimente en USB avec l'ampli directement.
L'ampli a été acheté d'occasion pour une bouchée de pain (un crime quand on connait ses qualités), et me permet d'avoir un son phénoménal sur une installation globalement récente.
Une seule limitation à connaitre : impossible d'afficher l'interface de l'ampli à la TV. Veillez juste à avoir tout réglé, ou avoir l'accès aux contrôles via une appli ou encore avec l'écran en façade. À ma connaissance l'eARC n'aurait pas eu cette limitation car la TV sait faire la bascule.
Mon seul regret est que je n'ai pas trouvé l'appareil sur ce site en premier, car Audiophonics propose encore une fois un des meilleurs prix sur la toile.
With its high bandwidth and 18Gb/s digital data rate, this extractor is capable of working with 4K2K@60Hz HDCP 2.3, HDR 10bits streams and accepts...
