Audio Extractor HDMI to Jack 3.5mm RCA ARC
This compact audio extractor allows you to recover the audio signal from an HDMI input and then output it as analog in RCA or Jack 3.5mm. The HDMI input also supports audio return via ARC technology.
Reference : 17375
49,90 €tax incl.
41,58 € tax excl.
audio extractor
Extracteur audio HDMI vers Jack 3.5mm RCA ARC
This compact audio extractor allows you to recover the audio signal from an HDMI input and then output it as analog in RCA or Jack 3.5mm. The HDMI input also supports audio return via ARC technology. The power supply of the device is done in 5VDC via a simple Micro USB connector.
Product typeAudio extractor
Input1* HDMI
Outputs1* Stereo RCA
1* Jack 3.5mm
ARC support
Dimensions73*65*27mm
Package1* Audio extractor
1* USB-A to Micro USB cable
InputHDMI
OutputJack 3.5mm
ColorSilver
This compact audio extractor allows you to recover the audio signal from an HDMI input and then output it as analog in RCA or Jack 3.5mm. The HDMI...
