CYP CM-1392M Scaler Composite / S-Video to HDMI 1080p@50/60 Hz
Video scaler very useful to connect properly any A/V device with a compsoite / S-video output to a modern display with HDMI input.
Reference : 14494
245,00 €tax incl.
204,17 € tax excl.
CYP CM-1392M
Scaler Composite / RCA / S-Video to HDMI
CYP CM-1392M is a video scaler which is very useful to connect properly any A/V device with a compsoite / S-video output to a modern display with HDMI input.
It is able to perform high-precision video stream conversion and can adapt your low-definition sources to meet the standards of your high-definition display or TV (HDTV and resolutions up to 1080p/WUXGA). It supports NTSC, NTSC4, PAL, PAL-M, PAL-N and can perform VGA-WUXGA up to 1920 x 1200 @60hz.
This scaler is really easy to use since it is able to detect the your display / monitor / TV settings and can switch automatically to the best resolution and framerate.
This video Scaler supports 3D adaptive deinterlacing technology and framerate conversions : 3/2 : 2/2.
Options d'ajustement vidéo
In addition to its function of upscaling the CM-1392M has a wide range of options to improve the final picture. Three buttons on the front panel are used to access a on-screen-display menu and enable the adjustment of contrast, brightness, hue, saturation, sharpness, color tone, levels and image ratio on the screen.
The CM1392M is delivered with its remote, which can be used to comfortably control all its functions and display options.
TypeVideo Scaler
Inputs1x Composite
1x RCA stereo audio analog (2Vrms)
1x S-Video (mini-Din 4 pin)
Outputs1x HDMI
HDMI standard1.3/1.4
Supported Input formatsNTSC, NTSC4, PAL, PAL-M, PAL-N
Video output resolution480p@60Hz, 576p@50 Hz, 720p@50/60 Hz
1080i@50 /60 Hz, 1080p@50/60 Hz
VGA@640x480,
SVGA@800x600, XGA@1024x768
WXGA@1360x768, WSXGA@1440x900
SXGA1280x1024, SXGA+@1400x1050
UXGA@1600x1200, WUXGA@1920x1200
Audio inputRCA stereo 2Vrms
Power Supply5V / 1.2A DC
Power Consumption4.1W
HousingAluminum
ColorBlue
Dimensions125mmx123mmx30mm
Package contents
1xHDMI Scaler
1x5VDC Power Supply
1xManual
1xRemote control
InputS-Video
OutputHDMI
ColorOther
