CYP CP-259UHD Scaler HDMI / Optical / Jack 3.5mm to Jack 3.5mm / Optical / HDMI UHD 4K@60Hz
The CYP CP-259UHD is a HDMI to HDMI UHD video scaler. It lets you connect your audio/video devices with an HDMI output to a latest-generation TV or monitor using an HDMI input.
By buying this product you get 38 loyalty points
Reference : 18118
389,00 €tax incl.
324,17 € tax excl.
CYP CP-259UHD
xxxCYP CP-259UHD Scaler HDMI / Optique / Jack 3.5mm vers Jack 3.5mm / Optique / HDMI UHD 4K@60Hz
Compact and versatile, it accepts a wide range of resolutions up to 4K@60Hz (4096×2160p, 4:4:4, 8-bit). It's easy to use, since the unit is able to automatically detect the parameters of the screen connected to its HDMI output in order to adapt the best output resolution and refresh rate to the screen. A Bypass mode is also available for unaltered signal retransmission.
This Video Scaler supports adaptive 3D deinterlacing and 3:2 / 2:2 framerate conversion.
The box directly integrates EDID and HDCP management.
Overall, the CYP CP-259UHD supports a wide range of audio formats, including LPCM 2.0/5.1/7.1, Bitstream and HD Bitstream via HDMI. Support for embedded or extracted audio is possible via its optical digital and stereo analog inputs and outputs (LPCM 2.0 only).
In addition to its upscaling function, the CYP CP-259UHD offers a wide range of options for perfecting the picture. Three buttons on the front panel provide access to and control of an overlay menu, offering adjustment of contrast, brightness, hue, saturation, sharpness, color tone, levels and screen aspect ratio.
It's also from this well thought-out OSD menu that you can set audio & video output preferences (activate or deactivate one or more outputs).
Product typeScaler HDMI to HDMI UHD
Inputs1x HDMI
1x Optical Toslink
1x 3.5mm jack
Outputs1x HDMI
1x Optical Toslink
1x 3.5mm jack
HDMI complianceHDMI 2.0 (DVI 1.0)
HDCP compliance2.x
Max. input video resolution4K@60Hz 4096×2160p (4:4:4, 8 bits)
Max. output video resolution 4K@60Hz 4096×2160p (4:4:4, 8 bits)
Audio inputs1x HDMI LPCM 2.0/5.1/7.1 input
1x 2-channel LPCM optical input (192kHz)
1x Analog input 3.5mm jack 2Vrms 499kΩ unbalanced
Audio outputs1x HDMI LPCM 2.0/5.1/7.1 output
1x 2-channel LPCM optical output (48Khz)
1x Analog line output 3.5mm jack 2Vrms 499kΩ unbalanced
 maximum HDMI cable lenght
1080p4K
8-bit12-bit8-bit
Input15m10m3m
Ouput15m10m3m
Power supply5V/2.6A DC
Power comsumption11W
Chassis materialAluminum
Dimensions102 × 25 × 147mm
Weight350g
Package1x HDMI to HDMI UHD scaler
1x AC adapter with AC connector adapters
InputJack 3.5mm
InputHDMI
OutputJack 3.5mm
OutputOptical Toslink
OutputHDMI
The CYP CP-259UHD is a HDMI to HDMI UHD video scaler. It lets you connect your audio/video devices with an HDMI...
