Converter HDMI UHD DTS Dolby Digital to SPDIF RCA
The CYP CPRO-SE2DD is an HDMI audio converter that supports Dolby Digital and DTS 2.0+ technologies. It allows the audio signal from an HDMI source to be decoded, resampled if necessary, and then redirected to a digital Coaxial or Optical or analog RCA Stereo output. In addition, the device also allows the use of an additional audio output such as an AV receiver or active speakers.
1 | LED Power ON/OFF |
2 | LED PCM |
3 | LED DTS |
4 | LED Dolby |
1 | Entrée HDMI |
2 | Sortie HDMI |
3 | Sortie RCA |
4 | Sortie Coaxial |
5 | Sortie Optique |
6 | Bypass HDMI / 2 Canaux |
7 | Bypass SPDIF / 2 Canaux |
8 | Port service (pour le constructeur uniquement) |
9 | Alimentation 5V DC |
Video bandwidth | 300MHz / 9Gbps |
Inputs | 1x HDMI 1x USB (Only for the manufacturer) |
Outputs | 1x HDMI 1x Coaxial 1x Optical 1x Stereo RCA |
Max HDMI cable length | Input : 10m @ 1080p, 5m @ UHD Output : 10m @ 1080, 5m @ UHD |
Power supply | 5V 2.6A DC |
Measurements | ||||||
Input | Output | Output level | THD+N (A-Weight) | Frequency response | SNR | Crosstalk |
HDMI 0dBFS | ||||||
HDMI | 0dBFS | < 0.00001% | +/-1dBFS | > 140dB | < -160dB | |
Optical | 0dBFS | < 0.00001% | +/-1dBFS | > 140dB | < -160dB | |
Coaxial | 0dBFS | < 0.00001% | +/-1dBFS | > 140dB | < -160dB | |
RCA | 2Vrms +/-0.1 | < 0.006% | +/-1dB | > 100dB | < -110dB |
Dimensions | 180 x 110.75 x 25mm |
Housing material | Metal |
Weight | 368g |
Color | Black |
Consumption | 2.5W |
Operating temperature | 0°C - 40°C |
Input | HDMI |
Output | HDMI |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | RCA |
DAC / ADC Chip | NC |
Color | Black |
