CYP CSLUX-1080P Scaler SCART to HDMI 1080Pp
By buying this product you get 28 loyalty points
Reference : 14495
285,00 €tax incl.
237,50 € tax excl.
CYP CSLUX-1080p
CYP CSLUX-1080P is a video scaler which is very useful to connect properly any A/V device with a SCART output to a modern display with HDMI input.
It is able to perform high-precision video stream conversion and can adapt your low-definition sources to meet the standards of your high-definition display or TV (HDTV and resolutions up to 1080p/WUXGA). It supports NTSC, PAL and can perform an upscalling up to HDMI HDTV 1080p with a color bit depth of 8/10/12 bit up to a distance of 6 meters.
This scaler is really easy to use since it is able to detect the your display / monitor / TV settings (EDID native resolution ) and can switch automatically to the best resolution and framerate. 6 DELs located on the front panel show in real-time the output resolution.
This video Scaler supports 3D adaptive deinterlacing technology and framerate conversions : 3/2 : 2/2.
Front and back panel
TypeVideo Scaler
Inputs1x SCART
Outputs1x HDMI
HDMI standard1.3/1.4
Supported Input formatsNTSC, PAL
Video output resolution576P / 720P / 1080I / 1080P
Power Supply5V / 2.6A DC
Power Consumption6W
HousingAluminum
Dimensions151mmx125mmx30mm
Weight340g
Package contents
1xScaler SCART / HDMI
1xPower Supply
1xManual
InputSCART
OutputHDMI
