HDMI to HDMI ARC Optical 4K CEC 3D Extractor
This compact HDMI ARC extractor allows you to recover the signal from a wired HDMI connection to both extract it to HDMI ARC (Audio Return Channel) and distribute the audio in Optical Toslink. The ARC function can be activated or not with a switch on the device. The extractor is compatible with 4K 30fps / 1080p 60fps streams as well as with 3D and CEC technologies.
Product type | HDMI extractor |
Input | 1* HDMI |
Outputs | 1* HDMI ARC 1* Optical Toslink |
Max TMDS rate | 340MHz |
Max transmission bitrate | 10.2Gbps |
Max current | 150mA |
Output formats | LPCM2.0 DTS Dolby-AC3 |
Max resolution | 2160p 30fps 1080p 60fps |
Supported audio formats | DTS-HD Dolby True HD LPCM 7.1 DTS Dolby AC3 DSD |
CEC support | |
3D support |
Dimensions (L*P*H) | 44*53*19mm |
Weight | 55g |
Color | Black |
Package | 1x HDMI extractor 1x USB-A to DC Jack Cable |
