Splitter HDMI ARC to SPDIF Coaxial Optical RCA Jack 3.5mm DTS Dolby AC-3 5.1
This compact audio extractor will allow you to simply extract the audio signal from an HDMI ARC input stream and then output to Coaxial, Optical, RCA stereo or an amplified 3.5mm jack headphone output.
Reference : 14323
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 02-04-2025.
HDMI Splitter
Extracteur HDMI ARC vers SPDIF Coaxial Optique RCA Jack 3.5mm DTS Dolby AC-3 5.1
This compact audio extractor will allow you to simply extract the audio signal from an HDMI ARC input stream and then output to Coaxial, Optical, RCA stereo or an amplified 3.5mm jack headphone output. The careful design of the unit allows it to support high sample rates up to 192kHz and also supports DTS and Dolby 5.1 formats on the Optical and Coaxial outputs.
Product typeHDMI Splitter
Input1x HDMI ARC
Outputs1x Coaxial
1x Optical
1x Stereo RCA
1x Jack 3.5mm
Max supported sampling rate192kHz
5.1 SupportVia Optical and Coaxial
Dimensions81.7 x 67 x 21.2mm
Weight115g
Case materialAluminium
Power supply5V DC via Micro USB
Package1x HDMI Splitter
1x USB-A to Micro USB cable
InputHDMI ARC
OutputCoaxial SPDIF
OutputOptical Toslink
OutputJack 3.5mm
Ca remplit son rôle !
Parfait pour extraire le son d'une sortie HDMI (ARC) d'un téléviseur ou rétroprojecteur, et l'injecter en optique dans un ampli. Ca marche !
This review has been posted for Splitter HDMI ARC to SPDIF Coaxial Optical RCA Jack 3.5mm DTS Dolby AC-3 5.1
This compact audio extractor will allow you to simply extract the audio signal from an HDMI ARC input stream and then output to Coaxial, Optical,...
