Stereo preamplifier module TA7630 RCA Jack 3.5mm
This Toshiba TA7630P chip-based preamplifier module, very easy to implement, will troubleshoot and replace a faulty headphone output. It can also be used as the basis for the development of a complete and affordable preamplifier / headphone amplifier, including volume control, bass and treble control, as well as an L/R balance. Its potentiometers have standard 6mm notched axes, a wide choice of buttons and cases are available to you. The preamplification section integrates an AOP 5532 mounted on DIP8 and therefore interchangeable.
Product type | Preamplifier |
Chip | Toshiba TA7630 |
AOP | 5532 |
Input | 1x RCA |
Outputs | 1x RCA 1x Jack 3.5mm |
Potentiometer | ALPS 50k, notched shaft 6mm |
SNR | > 90dB |
Headphone power | 30Ω to 300Ω, 100mV on average |
Dimensions | 100 x 50 x 21mm |
