This resolutely high-end balanced MMCX to 2.5mm jack cable is assembled by hand from 99.9999% purity OCC copper conductors themselves, composed of 22 strands x 4 x 0.08mm. Each of these conductors benefits from a silver plating as well as double insulation with a Litz layer as well as an outer TPE layer.
The Jack and MMCX connectors are CNC machined with a stainless steel casing and a copper conductor which does preserve all the precision of the signal.
Metal buckles firmly hold the conductors and provide excellent strength to the cable, which benefits from a great longevity.
SPECIFICATIONS | |||
Type | Modulation cable | ||
Conductor | 4x 22 strands x 0.08mm? Copper OCC Silver plated | ||
Isolation | Litz TPE | ||
Connectors | MMCX jack 2.5mm | ||
Length | 120cm | ||
Weight | 19g |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
