By buying this product you get 39 loyalty points
The BC130 Nyx Net Standard DD HIFI headphone cable features a high-end design with audiophile-grade materials. It features a balanced, gold-plated 4.4mm jack termination and DD HIFI's proprietary interchangeable connector system, allowing the user to choose between an MMCX or CIEM 0.78mm connection. This cable's OCC copper conductors feature a litz-wire structure for optimum signal transmission. In addition, this cable features a shield and two layers of internal insulation for effective protection against interference and to reduce noise levels. This makes the cable ideal for use with IEMs or high-end headphones, and for demanding music lovers.
DD HIFI Nyx Net Standard features 25.4AWG OCC copper conductors in a (1xØ0.08mm + 8x Ø0.05mm) x7 x4 configuration, and an overall Litz wire structure. These features ensure optimum signal transmission. In addition, shielding protects it from interference, and each conductor is individually insulated to preserve the transmission of different frequencies. These include HDPE insulation and SoftFlex PVC insulation.
The standard version of the DD HIFI Nyx Net features a balanced 4.4mm jack termination with gold-plated contacts, as well as interchangeable connectors allowing a choice between MMCX and CIEM 0.78mm. This cable is therefore compatible with the majority of IEMs available on the market. In addition, 3 versions of CIEM 0.78mm connectors are included:
Product type | Headphone/IEM cable |
Connectors | 1x Balanced gold-plated 4.4mm jack termination 4x interchangeable connectors (1x MMCX + 3x CIEM 0.78mm) |
COnductor material | OCC copper |
Conductors | (1xØ0.08mm + 8x Ø0.05mm) x7 x4 |
Structure | Litz wire |
Insulation | 1 : NUC (Japon) HDPE 2: SoftPlex PVC (USA) |
Shielding | |
External protection | High-density nylon braid |
Weight | 40g |
Length | 1.2m |
Package | 1x Headphone cable DD HIFI Nyx Net Standard 1x Pair of MMCX connectors 3x Pair of 0.78mm CIEM connectors |
Length (m) | 1.2 |
Shielding | Yes |
Section (mm²) | 0.16 |
Connector | Jack 4.4mm |
Connector | MMCX |
Connector | CIEM 0.78mm |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
