DD M110A Headphone Cable Lighning DAC to CIEM 0.78mm 1.2m
The DD M110A headphones cable features 0.78mm CIEM connectors and a lightning termination with integrated DAC. This cable allows you to enjoy CD-quality listening even with your smartphone.
Reference : 20538
56,99 €tax incl.
47,49 € tax excl.
Shipping date: 20-05-2025.
DD M110A picture
The DD M110A headphones cable features 0.78mm CIEM connectors and a lightning termination with integrated DAC. This cable allows you to enjoy CD-quality listening even with your smartphone. In fact, the cable's integrated DAC chip is capable of supporting streams up to PCM 24bit 48kHz, while providing 2x8.4mW of power under 30 ohms to drive earphones. The structure and materials used in the design of the DD M110A are of the highest quality.
Product typeHeadphones/IEM cable
ConnectorsCIEM 0.78mm
TerminaisonLightning (DD C100)
Integrated DAC
Supported sample ratesPCM 24bit 48kHz
Dynamic range> 101dB (18-24bit 30 ohm, A-WT)
SNR> 120dB (A-WT)
Frequency response20Hz-20kHz
Output power2x8.4mW @ 30 ohm
Control protocolCTIA
Length1.2m
Package1x DD M110A
Length (m)
  • 1.2
Shielding
  • Yes
Section (mm²)
  • N/A
Connector
  • CIEM 0.78mm
Conductors material (Cable)
  • N/A
Conductors Plating (Cable)
  • None
The DD M110A headphones cable features 0.78mm CIEM connectors and a lightning termination with integrated DAC. This cable allows you to enjoy...
