DD M110C Headphone Cable USB-C to MMCX Portable DAC Headphone Amplifier 1.2m
New
The DD M110C headphones cable features MMCX connectors and a USB-C termination with integrated DAC. This cable allows you to enjoy high-resolution streams even with your smartphone.
Reference : 20542
56,99 €tax incl.
47,49 € tax excl.
Shipping date: 29-04-2025.
DD M110CHeadphone Cable USB-C to MMCX Portable DAC Headphone Amplifier ES9603Q OFC Copper 1.2m
DD M110C picture
The DD M110C headphones cable features MMCX connectors and a USB-C termination with integrated DAC. This cable allows you to enjoy high-resolution streams even with your smartphone. In fact, the ES9603Q headphone amplifier DAC chip built into the cable supports streams up to PCM 32bit 384kHz, while providing 2x50mW of power under 32 ohms to drive earphones. The structure and materials used in the design of the DD M110C are of the highest quality. There's also direct control of play/pause/next functions, as well as call handling via a microphone.
Product typeHeadphones/IEM cable
ConnectorsMMCX
TerminaisonUSB-C
Integrated DAC
DAC ChipES9603Q
SNR> 120dB (32 ohm, A-WT)
Noise floor< 3uV (A-WT)
THD+N< 0.008% (32 ohm load)
Output power2x50mW @ 32 ohm
Cable conductor materialOFC copper
Control functionsPlay/Pause/Track skip
Phone call microphone
Package1x DD M110C
Length1.2m
Length (m)1.2
ShieldingNC
Section (mm²)N/A
ConnectorMMCX
DD M110C Headphone Cable USB-C to MMCX Portable DAC Headphone Amplifier ES9603Q OFC Copper 1.2m
The DD M110C headphones cable features MMCX connectors and a USB-C termination with integrated DAC. This cable allows you to enjoy high-resolution...
