DD M130B USB-C to CIEM 0.78mm Copper OCC Cable Portable Headphone Amplifier DAC ES9603Q 1.2m
The M130B cable from ddHiFi is an all-in-one headphone cable, which as well as offering signal transmission via an OCC copper core, includes an ES9603Q chip that acts as a DAC and headphone amplifier. Not only does this cable offer digital/analogue conversion at a sampling rate of up to PCM 384kHz, it also boasts an output power of 45mW+45mW at 32Ω.
Reference : 19673
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 16-04-2025.
DD M130B : Front view
ddHiFi M130B : OCC copper core
To ensure optimum data transmission, the ddHiFi M130B cable uses a conductor made up of 49 strands of 0.06mm OCC copper coupled with a shield made of 112 strands of 0.05mm OFC copper.
DD M130B : Conductor and shielding
DD M130B : USB-C connector with internal chip diagram
ddHiFi M130B : ES9603Q chip
The M130B cable is equipped with an ESS ES9603Q chip, enabling it to convert files up to PCM 384kHz, allowing you to enjoy tracks in lossless format, generally offered by streaming platforms at a maximum of 192kHz. Furthermore, thanks to the ES9603Q chip, the M130B cable offers an output power of 45mW+45mW at 32Ω, so it can drive the majority of earphones on the market.
ddHiFi M130B : MEMS microphone
Nestled inside the splitter is a high-performance MEMS microphone that can be used for everyday phone calls and other tasks. The central button on the splitter can be used to control your phone calls or music playback.
DD M130B : spliter
Product typeHeadphone cable
Portable DAC
Mobile headphone amplifier
Connectors1x USB-C
2x CIEM 0.78mm
Length1.2m
Conductive materialOCC Copper
Shielding materialOFC Copper
DAC chipES9603Q
Supported sampling ratesPCM up to 384kHz
Dynamic range>120dB
Total harmonic distortion more noise (THD+N)<0.008% @32Ω
Signal-to-noise ratio (SNR)≥112dB
Noise level<3µV
Output power45mW+45mW @32Ω
Crosstalk<-60db 32="" td="">
ColorCopper
Poids26g
Package1x ddHiFi M130B
OutputCIEM 0.78
DAC / ADC ChipES9603Q
Max sampling rate384kHz
ColorCopper
Length (m)1.2
ShieldingYes
Section (mm²)N/A
ConnectorUSB-C
ConnectorCIEM 0.78mm
ClassN/A
The M130B cable from ddHiFi is an all-in-one headphone cable, which as well as offering signal transmission via an OCC copper core, includes an...
