By buying this product you get 45 loyalty points
The Furutech ADL iHP-35Hx-XLR headphone cable has been specially designed for use with Sennheiser HD 800 headphones and headphone amplifiers with two 3-pin XLR headphone outputs. This high-end cable uses Alpha-treated OFC copper conductors. The conductors benefit from a cryogenization and demagnetization process for perfect signal transmission. Connector contacts are rhodium-plated, providing effective protection against oxidation and corrosion.
Please note that this cable cannot be connected to a line output, otherwise your equipment may be damaged. This headphone cable must be connected to a specific 2x XLR 3-pin headphone output.
Product type | Cable for headphone |
Connectors | 2x XLR 3-Pin 2x CF-H800 connectors (Sennheiser HD800) |
Conductors material | Copper OCC Alpha treatment |
Connectors contact plating | Rhodium |
Heaphones compatibility | Seinheiser HD800 / HD800S |
Length | 3m |
Package | 1x Headphone cable FURUTECH ADL iHP-35Hx-XLR |
Length (m) | 3.0 |
Shielding | NC |
Section (mm²) | N/A |
Connector | XLR |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
