The Ikko CTU02 cable for headphones and in-ear monitors benefits from high manufacturing quality and top-of-the-range materials to enhance signal transmission from your source to your IEMs or headphones. In fact, it incorporates a 145µm-diameter central conductor made of silver-plated SPCOCC monocrystalline copper wire for optimum conductivity and superior transmission quality. Connectivity features 0.78mm CIEM connectors and interchangeable jack termination with 2.5mm, 3.5mm and 4.4mm jack plugs. The shell of the jack connectors is made from a blend of monocrystalline copper and aluminum for high durability and pleasing looks.
Product type | Cable for IEM / headphones |
Conductor material | Single-crystal copper SPCOCC |
Conductor plating | Silver |
Connectors | CIEM 0.78mm |
Terminaison | Interchangeable jack 2.5mm / jack 3.5mm / jack 4.4mm |
Cable length | 1.2m |
Color | Black / transparent |
Package | 1x IKKO CTU02 cable 1x 2.5mm jack termination 1x 3.5mm jack termination 1x 4.4mm jack termination |
Length (m) | 1.2 |
Shielding | NC |
Section (mm²) | N/A |
Connector | Jack 3.5mm |
Connector | Jack 4.4mm |
Connector | Jack 2.5mm |
Connector | CIEM 0.78mm |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
