MEZE XLR 4 Pins to 2x Mini XLR Balanced Interconnect Cable Silver Plated PCUHD Copper 2.5m
This balanced Meze cable was specifically designed for use with headphones. It features an exceptional design, using silver-plated Furukawa PCUHD copper conductors, ensuring incredible electrical conductivity for perfect audio signal transmission. Furukawa cables are known for their ability to provide open, yet highly detailed sound with perfectly controlled transients and punchy bass.
Reference : 16505
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 25-04-2025.
Meze Headphone Cable
2x Mini XLR to XLR 4 Pins Balanced Silver Plated PCUHD Copper 2.5m
Meze Câble pour casque 2x Mini XLR vers XLR 4 Pins Symétrique Cuivre PCUHD Plaqué Argent 1.3m
By combining a molding process with a post-treatment that does not use hot extrusion or lamination, no impurities corrupt the conductors. Also, no gas burners are used in the manufacturing process to ensure that the oxygen level in the copper is perfectly controlled, as it is measured at 5ppm, which is lower than the standard required for OFC (Oxygen Free Copper).
Regarding the connectivity of this cable, it has two Mini XLR connectors and a 4.4mm jack connector, allowing a balanced connection. Each connector is equipped with gold-plated contacts, to maintain excellent conductivity and durability.
Product typeHeadphone balanced cable
Length2.5m
Connectors2x XLR 4 pins
1x Jack 4.4mm
Cable conductors materialPCUHD Copper
Cable conductors platingSilver
Conductors composition140*0.04mm
Sheath materialTPE
SolderingJensen Silver 4%
Length (m)2.5
ShieldingNC
Section (mm²)N/A
ConnectorXLR
ConnectorMini XLR
This balanced Meze cable was specifically designed for use with headphones. It features an exceptional design, using silver-plated Furukawa PCUHD...
