OYAIDE HPC-35HDX 3.5mm Jack Cable for HD650 / 600/580 / HD-25SP-II 1.3m
Reference : 7729
109,00 €tax incl.
90,83 € tax excl.
This superb high-end cable is equipped with a 3.5mm jack plug plated both Rhodium and Silver.
The contact pins are made of a copper alloy machined precisely and plated by 24 gold-plated.
The cable conductors are PCOCC-A copper and PFA insulated.
DIn addition, this cable uses a high-quality weld that is specific to the brand: SS-47. Unlike conventional welding, which uses 3N (99.9%) of pure tin, the SS-47 uses 4N, ie 99.993% pure tin, thus excluding more impurities.
In order to improve the conductivity, the weld also contains 4.7% silver and 1.7% copper.
The materials used for this cable contribute to a marked improvement in reliability and sound quality.
Features:/ Strong>
  • Cable: HPC-23T (N) 1P shielding, parallel structure 2P (φ2.5x2)
  • Insulation: PFA
  • Conductor: copper PCOCC-A (Monocrystalline high purity copper)
  • Sheath: TPE
  • Connectors 3.5mm Plug Plated Brass Plated Silver (1.5μ) and Rhodium (0.3μ)
  • 24K Gold Plated Headphone Jack Connectors and Polypropylene Molded
  • Welding: SS-47
  • Cable length: 130cm
Compatible with the following SENNHEISER headphones:
  • HD650
  • HD600
  • HD580
  • HD565
  • HD545
  • HD535
  • HD525
  • HD445
  • HD265
  • HD-25SP-II
https://www.audiophonics.fr/images2/7729/7729_oyaide_HPC-35HDX_4.jpg
https://www.audiophonics.fr/images2/7729/7729_oyaide_HPC-35HDX_6.jpg
https://www.audiophonics.fr/images2/7729/7729_oyaide_HPC-35HDX_5.jpg
Length (m)1.3
Section (mm²)N/A
ConnectorJack 3.5mm
Mr Cédric Chassaing
Bonjour.
C’est bien la première fois que je rédige un commentaire de satisfaction après achat. J’avais cependant déjà possédé des câbles Oyaide au sein de mon système hi-fi. Alors lorsque j’ai constaté que la marque proposait un câble de remplacement pour le fameux HD-650 de Sennheiser, modèle de la marque et référence de très nombreux amateurs du casque ouvert dont je suis, j’ai tout de suite voulu essayer d’ « influer sur ce maillon faible de la chaîne » en remplaçant le câble d’origine de 3.00 m par celui de la marque japonaise réputée, pour la pureté de son cuivre, sa teneur en argent et sa longueur d’1.30 m. A l’époque du test initial, mon casque était branché dans un DAC OPPO HA-2 SE, lui-même branché dans mon iPhone connecté à Qobuz abonnement Hi-Fi Sublime+ (via un câble USB / Lightning Audioquest Cinnamon 15 cm). L’ampli du DAC était muni d’un amplificateur des basses fréquences ; avec le câble d’origine, j’avais pris l’habitude de l’enclencher, (bass + on), bien que généralement je n’utilise de correction de tonalité sur aucun de mes systèmes, afin d’éviter tout risque de filtrage en peigne. Le seul faible défaut imputable aux écouteurs Sennheiser est en effet, un léger manque d’assise dans le grave. Or, une fois l’amplificateur des basses éteint, (bass + off), et le câble Oyaide HPC-35HDX Jack 3.5mm 1.30 m branché, ces basses fréquences sont apparues avec beaucoup plus de définition et de densité. Il délivre à peu de frais ce qui manquait à ce très grand casque de moyenne gamme (moins de € 350,00) fabriqué par l’un des meilleurs constructeurs en la matière. L’association devient donc évidente. Existe en black et silver.
Système d’écoute pour le câble :
OYAIDE HPC-35HDX
Câble Jack 3.5mm : https://www.audiophonics.fr/fr/cables-pour-casques/oyaide-hpc-35hdx-cable-35mm-pour-hd650600580hd-25sp-ii-13m-p-7729.html
pour HD650 : https://fr-fr.sennheiser.com/casque-audiophile-haute-qualite-hd-650
iPhone Xs Max : https://www.audioquest.com/cables/digital-cables/usb-lightning/cinnamon
OPPO HA-2 SE : https://www.oppodigital.com/headphone-amplifier-ha-2SE/
This review has been posted for OYAIDE HPC-35HDX 3.5mm Jack Cable for HD650 / 600/580 / HD-25SP-II 1.3m
