This Thieaudio Oceania headphone cable features MMCX connectors and interchangeable termination: 3.5mm jack, balanced 2.5mm jack and balanced 4.4mm jack. It has a cross-section of 0.2mm² (AWG24) and features a Litz wire structure with 530 copper strands of 0.01mm and 119 strands of 0.6mm palladium-plated silver. Thanks to these properties, the cable avoids distortion due to the skin effect and offers enhanced resistance to corrosion and oxidation. The use of an interchangeable termination offers a high level of compatibility with many Hi-Fi devices and headphone amplifiers.
Product type | MMCX headphone cable to interchangeable termination |
Connectors | 1x Interchangeable termination: 3.5mm jack, balanced 2.5mm jack, balanced 4.4mm jack 2x MMCX |
Length | 1.25m |
Conductors | 530x 0.01mm copper strands 119x 0.6mm palladium-plated silver strands |
Structure | Litz wire |
Color | Blue |
Package | 1x Thieaudio Oceania MMCX headphone/IEM cable 1x TRRS balanced 2.5mm jack termination 1x TRS single-ended 3.5mm jack termination 1x TRRRS balanced 4.4mm jack termination |
Length (m) | 1.25 |
Shielding | Yes |
Section (mm²) | 0.25 |
Connector | MMCX |
Connector | Jack 3.5mm |
Connector | Jack 4.4mm |
Connector | Jack 2.5mm |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | Palladium |
