COMPLY TW-200-C Set of 3 Pairs of Memory Foam Eartips (L) for Sony True Wireless
These Comply TrueGrip Pro memory foam tips are designed to fit Sony True Wireless earphones perfectly. They feature a unique design that seamlessly seals the ear canal to block out external noise for better sound and call clarity, giving you the best audio experience. In addition, TrueGrip Pro tips feature a shorter design than traditional tips, allowing for a perfect fit in the charging case without sacrificing in-ear comfort.
2.0 / 5
Reference : 17474
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 24-04-2025.
COMPLY TW-200-C
Comply TrueGrip Pro Lot de 3 Paires d'embouts (M) pour Sony True Wireless
  • Unshakeable fit : The memory foam conforms to the shape of the ear, providing all-day comfort and support.
  • Optimal performance : Comply eartips reduce unwanted outside noise so you can increase your listening level at lower volumes, protecting your hearing.
  • Easy to use : Ear tips attach easily, quickly and securely to your earphones.
  • Charger-friendly : Comply eartips are specially designed to fit most wireless charging cases without interfering with charging.
  • Additional protection : The built-in TechDefender™ system protects your earphones' sound tube from moisture and dirt.
Technical characteristic
Product typeEartips for Sony True Wireless
SizeL
MaterialMemory foam
CompatibilitySony Linkbuds S
Sony WF-1000X
Sony WF-1000XM3
Sony WF-1000XM4
Sony WF-C500
Sony WF-SP700N
Sony WF-SP800N
Sony WF-XB700
Quantity3x Eartips pairs
Très déçu
Mousses "L" vendues comme compatibles avec le Sony WF1000-XM4. C'est effectivement compatible mais la taille n'est pas du tout équivalent au L original. J'ai perdu 70% de réduction de bruit et les écouteurs ne tiennent pas dans les oreilles. 27€ de perdus !
2 étoiles car si les mousses vous conviennent elles ne sont pas si mal : mousse à mémoire de forme, pas trop agressif sur l'oreille, ont l'air plus résistantes que les mousses originales.
This review has been posted for COMPLY TW-200-C Set of 3 Pairs of Memory Foam Eartips (L) for Sony True Wireless
These Comply TrueGrip Pro memory foam tips are designed to fit Sony True Wireless earphones perfectly. They feature a unique design that seamlessly...
