The product is excellent. The seller is very relevant and helpful. Very fast shipping 2 days. This is my next favorite shopping company. Thank you very much for everything.
Rhodium plated Jack 3.5mm connector ⌀5mm (Unit)
The 3.5mm Jack compatible FT-735 connectors have been shaped around Furutech's know-how.
This connector consists of an Alpha treated phosphor bronze conductor, Teflon insulation to minimize impedance and a non-magnetic stainless steel body to reduce damping.
Conductor | One piece Rhodium-plated α (Alpha) Pure copper conductor |
Ground conductor | Rhodium-plated α (Alpha) Copper Alloy |
Insulation | Special grade Nylon Glass Fiber Resin |
Cable clamp | Copper alloy |
Housing material | Stainless |
Connection type | To solder |
Acceptable cable diameter | 5mm |
Total length | 41mm |
Housing dimensions | 10 x 25mm |
Color | Argent |
Sold by the unit | - |
Max cable diameter (mm) |
Mounting type |
Connectic |
Contacts number |
Contacts Material (Connector) |
Contacts Plating (Connector) |
Average votes 4.3 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
osman b.
Po Marn K.
Adrien F.
