Heat-Shrink Sheath 2:1 Ø12mm White (1m)
This heat shrinkable sheath has a diameter of Ø12mm and a shrink ratio of 2:1.  Its intermediate size thickness is designed to ensure excellent resistance to mechanical stress while maintaining a high degree of flexibility.
Reference : 14347
1,20 €tax incl.
1,00 € tax excl.
Shipping date: 29-04-2025.
Heat-shrink Sheath
2:1 Ø12mm 1m (White)
Gaine Thermorétractable 2:1 Ø12mm 1m (Blanche)
The sheath adapts to irregular shapes and provides very good insulation and sealing. It is halogen-free and has a flame-retardant design. It is also RoHS certified.
The ratio of 2:1 means that the diameter of the sheath once heated will be divided by 2. The initial diameter of this sheath is 12mm, once heated and shrunk its diameter will be 6mm.
Product typeHeat-shrinkable sheath
Length1m
Initial diameterØ12mm
Retraction Ratio2:1
Diameter after shrinkageØ6mm
Longitudinal shrinkage ratio± 8%
Shrink temperature110°C
Sheath thickness before shrinking± 0.3mm
Sheath thickness after shrinkage± 0.6mm
Temperature resistance-55 à +125°C
Dielectric strength≥ 15Kv/mm (IEC243)
CertificationRoHS
ColorWhite
ColorWhite
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)12.0
This heat shrinkable sheath has a diameter of Ø12mm and a shrink ratio of 2:1.  Its intermediate size...
