AUDIOPHONICS Heat-shrink tubing 3:1 Ø12mm Red (2x50m)
This set of 2 red heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed to the sheath with an arrow to indicate the plus and minus polarities or the direction in which the cables are connected.
Reference : 13256
3,50 €tax incl.
2,92 € tax excl.
Shipping date: 24-04-2025.
Audiophonics Heat Shrinkable Sleeve
Heat Shrinkable Sleeve for Cables 3:1 Ø 12mm Red (x2)
Gaine thermo audiophonics
This set of 2 red heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed to the sheath with an arrow to indicate the plus and minus polarities or the direction in which the cables should be connected.
The 3:1 retractation ratio of this sleeve means that once heated, the diameter of the sleeve will be divided by 3.
Product typeHeat shrinkable sleeve
Max cable diameter12mm
Retractation ratio3:1
Dimensions50 x 20mm
ColorRed
Quantityx2 (2 units)
ColorRed
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)12.0
Gaine thermo rouge
Permet d'avoir une finition de qualité avec en plus la direction du câble pour la pose.
This review has been posted for AUDIOPHONICS Heat-shrink tubing 3:1 Ø12mm Red (2x50m)
This set of 2 red heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed...
