AUDIOPHONICS Heat-shrink tubing 3:1 Ø18mm Red (x2)
This set of 2 red heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed to the sheath with an arrow to indicate the plus and minus polarities or the direction in which the cables are connected.
Reference : 17840
3,50 €tax incl.
2,92 € tax excl.
Shipping date: 24-04-2025.
Audiophonics Heat Shrinkable Sleeve
Heat Shrinkable Sleeve for Cables 3:1 Ø18mm red (x2)
Thermo sheath
This set of 2 red heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed to the sheath with an arrow to indicate the plus and minus polarities or the direction in which the cables should be connected.
The 3:1 retractation ratio of this sleeve means that once heated, the diameter of the sleeve will be divided by 3.
Product typeHeat shrinkable sleeve
Max cable diameter18mm
Retractation ratio3:1
Dimensions50*30mm
ColorRed
Quantityx2 (2 units)
ColorRed
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)18.0
This set of 2 red heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed...
