Heat-shrink tubing 3: 1 Ø09.5mm Black (1m)
Reference : 4684
2,50 €tax incl.
2,08 € tax excl.
Shipping date: 29-04-2025.
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 3: 1 means that the diameter of the sheath once heated will be divided by 3: for example for a 12mm sheath, after being heated its diameter will be 4mm.
Diameter: 9.5mm => about 3.1mm after retraction.
https://www.audiophonics.fr/images2/GAINES-THERMO_1.jpg
Specifications:
  • Retractable Ratio: 3: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 120 ° C
  • Melting Temperature of Internal Adhesive Layer: 70 - 90 ° C
  • Sheath Thickness Retractable : +/- 0.55mm
  • Sheath Thickness After Shrinkage : +/- 1.45mm
  • Temperature Resistance: -45 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 9.5mm
  • Length: 1m
  • Color Black
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)9.5
3 reviews
Excellente gaine thermo collante pour de superbe finition sur tout type de câble.
This review has been posted for Heat-shrink tubing 3: 1 Ø09.5mm Black (1m)
Je rejoints les commentaires de Benjamin. Il faut absolument un decapeur thermique, sinon je suis trés satisfait du résultat final sur la finition obtenue avec mes cables Harmonic Technology Ref 9 Hp .....
Gaine assez épaisse.
1ère expérience pour moi...
J'ai essayé au sèche cheveux, oubliez de suite !
Je suis fait prêter un souffleur thermique et là impeccable, il faut vraiment y aller par petites touches de quelques secondes, pour pas également faire fondre la gaine du câble lui même.
Impeccable pour améliorer l'esthétique de vos câbles DIY, utilisé pour recouvrir câble HP + fiches bananes (diamètre extérieur 4,5 ou 5).
