Heat-shrink tubing 3:1 Ø12.7mm Transparent (1m)
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
4.7 / 5
Reference : 5624
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 29-04-2025.
Thermo Retractable sheath
Transparent thermo-retractable sheath 3:1 Ø12.7mm (Length 1m)
Gaine thermo rétractable
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 3: 1 means that the diameter of the sheath once heated will be divided by 3: for example for a 12mm sheath, after being heated its diameter will be 4mm.
Diameter: 12.7mm => about 4.2mm after retraction.
Type of productThermo-retractable sheath
Retractable ratio3:1
Diameter before shrinkingØ12.7mm
Diameter after shrinkingØ4.2mm
Shrink temperature70 - 120°C
Melting temperature of internal adhesive layer70 - 90°C
Sheath thickness front retract+/-0.68mm
Sheath thickness after shrinkage+/-1.70mm
Temperature resistance-45 à +125°c
Dielectric rigidity ≥15 Kv/mm (IEC243)
CertificationsRoHS
Length1m
ColorTransparent
ColorTransparent
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)12.7
3 reviews
De la qualité
Produite de grande qualité
Très bonne qualité , de bonne épaisseur, pour une finition professionnelle
This review has been posted for Heat-shrink tubing 3:1 Ø12.7mm Transparent (1m)
La qualité
Gaine d'excellente qualité, pour un résultat parfait.
Finition très pro
Efficace mais attention !
Très bon produit, utilisé pour finition entre fiches bananes et câble 2x2,5mm, la rétractation est suffisante et le fini qualitatif et souple. Cependant pas de chauffe au briquet, celui-ci noircit la gaine, pistolet air pulsé ou gaz recommandé pour une finition transparente et propre.
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic,...
