Heat-shrink tubing 3:1 Ø30.0mm Black (1m)
Reference : 7162
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 16-06-2026.
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 3: 1 means that the diameter of the sheath once heated will be divided by 3: for example for a 12mm sheath, after being heated its diameter will be 4mm.
Diameter: 30mm => about 10mm after retraction.
https://www.audiophonics.fr/images2/GAINES-THERMO_1.jpg
Specifications:
  • Retractable Ratio: 3: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 120 ° C
  • Melting Temperature of Internal Adhesive Layer: 70 - 90 ° C
  • Sheath Thickness Front Retract : +/- 0.78mm
  • Sheath Thickness After Shrinkage : +/- 2.10mm
  • Temperature Resistance: -45 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 30mm
  • Length: 1m
  • Color Black
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)30.0
Du costaud
Un peu difficile à mettre en oeuvre du fait de l'épaisseur du matériau mais résultat parfait avec la colle intégrée. Très rigide une fois refroidi. Emballage impeccable et livraison en 72h
This review has been posted for Heat-shrink tubing 3:1 Ø30.0mm Black (1m)
