Pack x7 Heat-shrink tubing 3:1 Ø3.2-15.7mm Black (500mm)
Reference : 11906
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 24-04-2025.
Here is a set of 7 black heat shrink tubing of 7 different diameters, and self-adhesive. The glue allows the sheath when heated to be still and not move at all.
A ratio of 3: 1 means that the diameter of the sheath once heated will be divided by 3: for example for a 9mm sheath, after being heated its diameter will be 3mm.
Specifications:
  • Retractable Ratio: 3: 1
  • Diameter (mm): 3.2 / 4.8 / 6.4 / 7.9 / 9.5 / 12.7 / 15.7
  • Length: 50cm
  • Color: Black
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)3.2
Max cable diameter (mm)7.9
Max cable diameter (mm)15.7
Max cable diameter (mm)6.4
Max cable diameter (mm)4.8
Max cable diameter (mm)12.7
Max cable diameter (mm)9.5
10 reviews
Super gaines.
Effectivement ces gaines se collent et se moulent parfaitement.
Solides et suffisamment épaisses pour que l'on obtienne un excellent résultat.
Merci Audiophonics.
This review has been posted for Pack x7 Heat-shrink tubing 3:1 Ø3.2-15.7mm Black (500mm)
gaines
les gaines sont épaisses, très solides, idéales pour un travail propre et efficace...
Bon produit
Facile à utiliser,très résistant.
Óptimo producto.
Práctica selección de varios diámetros para distintos cables. Sella perfectamente y adhiere a todo tipo de superficie: fundas de PET, cordones de algodón, terminaciones audio, etc.
Fácil de trabajar, aunque sin una pistola de calor profesional.
Très bon produit,solide,facile d'emploi.
