Heat-shrink tubing 4: 1 Ø16.0mm Black (1m)
2.5 / 5
Reference : 4690
5,30 €tax incl.
4,42 € tax excl.
Shipping date: 07-07-2026.
Thermo-retractable sleeve with a ratio of 4: 1, internally equipped with an adhesive layer ensuring better maintenance on any type of surface (plastic, rubber, metal ...)
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 4: 1 means that the diameter of the sheath once heated will be divided by 4: for example for a 12mm sheath, after being heated its diameter will be 3mm.
Diameter: 16.0mm => about 4.0mm after retraction
https://www.audiophonics.fr/images2/GAINES-THERMO_1.jpg
Specifications:
  • Retractable Ratio: 4: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 120 ° C
  • Melting Temperature of Internal Adhesive Layer: 70 - 90 ° C
  • Sheath Thickness After Shrinkage: +/- 2.00mm
  • Temperature Resistance: -45 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 16mm
  • Length: 1m
  • Color Black
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)16.0
2 reviews
Inutilisable pour ma part
La gaine présente un défaut de fabrication. L'épaisseur de celle-ci n'est pas égale sur sa circonférence. La gaine se déforme lors de sa rétractation avec un briquet.
This review has been posted for Heat-shrink tubing 4: 1 Ø16.0mm Black (1m)
materiel ok, emballage inadapté
gaines reçues pliées dans des sacs de 8cm.... donc beaucoup de pertes à cause des pliures..
