Audiophile regulated power supply for any Hifi device running on 5V (DAC, digital sources for example).
Here is a regulated and stable linear power supply for any high quality DIY audiophile project. All the necessary technical refinements are incorporated into this dedicated audio power supply.
It includes a Hexfet IRF controller of series 34Z driven by low-noise OP Analog-Device and not an integrated circuit. The incorporated EMI RFI filtering ensures a very low noise (ripple) of electrical pollution (- of 30mv).
The components of this power supply are of first quality with DALE resistors and 4 capacitors of filtering BC of 220μf each. A fuse F0.25A 250V ensures the protection of the device. The benefits of a linear quality feed are better readability of the acute medium and a much better cut out.
This regulated linear power solution developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two DC 5.5 / 2.1mm output jacks, this power supply with an extremely stable 25VA transformer even under heavy load will allow you to make the best of audio connected.
As this power supply do not have over current protection, the load should not exceed it's capacity.
For use with a RaspTouch: If a yellow flash appears on the screen, you can adjust the output voltage of the power supply using the screw on the back of the unit until the flash disappears.
AC Power cable sold separately.
Input voltage
AC 220V
Output Voltage / current
5V 2.0A MAX Continuous 5V 3.5A DC (5 min)
Outputs
Jack DC 5.5/2.1mm 2x USB-A 5V
Input
IEC
Vibration-proof molded transformer 25VA shielded
Internal fuse
0.5A Fast
Case material
100% Brushed & Sandblasted Aluminium
Anodising
Yes
Dimensions
174 x 100 x 51mm
Weight
0.85kg
DC 5.5/2.1 jack cord and mains cable not included.
Presentation of the linear power supply regulated by The Hans Beekhuyzen Channel We recommend for the ALLO DIGIONE this Power supply
Input
IEC C14
Output
Jack DC 5.5/2.1mm
Color
Black
Output voltage (V)
5.0
Output current (A)
2.0
Input voltage (V)
230.0
Power Supply
Linear
We deliver all over France, and internationally. To find out the amount of shipping costs, simply go to your cart once you have added the desired products. To discover our different services and delivery options, click on the following logos :
Gaetan M.
Rapport qualité prix imbattable Après 2 semaines d'utilisation je dois avouer que le changement a été immédiatement perçu, cette alimentation linéaire alimente un Octavio Stream, branché sur un Onkyo TX-rz 50 et enceintes Klipsch rp-8000f. Dès les premières secondes d écoute, on ressent la différence surtout à mi-volume, un son aéré avec plus de détails et de précision sur les instruments. Cette alimentation est le produit le moins cher de mon installation complète mais sans aucun doute là ou j ai été le plus bluffé par la qualité du son. Merci à Audiophonics de m'avoir proposé un tel produit pour un prix défiant toute concurrence
This review has been posted for AUDIOPHONICS LPSU25 Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA
Loic T.
pour mon khadas tone2 pro fonctione parfaitement, impecable !!!
Jean-Marc M.
Excellent et indispensable Cela fait à présent trois semaines que j'utilise cette alimentation linéaire régulée sur mon lecteur réseau Octavio Stream. Sur mon installation la différence est impressionnante. Tout est sublimé du grave à l'aigu, les voix sont encore plus réalistes, l'aération, les silences, ... Pour information mon lecteur réseau me sert uniquement pour la lecture de Qobuz. Il est relié en optique toslink à un préampli à tubes , ampli à tubes et enceintes à HP à excitation et à haut rendement (LB8EX d'EMS Acoustics). Sur mon alimentation le câble secteur est un Réal Câble Kapton et l'alimentation est reliée au lecteur Octavio via un câble Qed USB A vers USB C. Cette alimentation est indispensable pour tirer le meilleur de vos sources en 5V. Un grand merci à Audiophonics pour créer un tel produit, à un prix abordable et avec un rapport qualité prix exceptionnel.
Christophe C.
Produit qualitatif Envoi rapide et article bien protégé. L'alimentation est de tràs bonne finition et ses prestations sont excellentes. Les pavillons de mes Klipsch délivrent un aigu et un medium plus clairs, plus fins et ciselés, un voile s'est levé ! Les graves sont revenus dans leur juste proportion, ils ne sont plus baveux. La musique est plus aérée, c'est transparent et analytique. J4obtiens des prestations de très haut niveau sur un rasp 3B plus et une puce ess 9023 branchés sur un NAD C316. Produit vivement recommandé! Bravo audiophonics
Dominique L.
Satisfait Initialement achetée il y a quelques mois, pour un Wiim Pro, je me suis vite rendu compte que cette alimentation prenait tout son intérêt pour mon petit dac Smsl Su-1. Les graves me semblent plus profonds sans devenir lourds et globalement l'écoute est plus aérée. En revanche, et je ne sais pas pourquoi, j'ai préféré revenir à l'alimentation d'origine pour le Wiim plutôt que la LPSU25. La fabrication de l'alimentation Audiophonics est du meilleur niveau, surtout à ce prix. Même après plusieurs heures d'utilisation, elle ne chauffe pas. Très content de cet achat.
