AUDIOPHONICS Double Regulated Linear Power Supply 5V / 12V 30W T-Amp V-DAC2 LT1085
The Audiophonics team is proud to be able to offer you a regulated linear power supply for the clean supply of small amplifiers, DACs, etc. This one has two lockable GX12 (aviation type) outputs, one outputting a voltage of 5V 1.5A and the other 12V 1.5A.
Reference : 8894
99,00 €tax incl.
82,50 € tax excl.
Alimentation linéaire régulée
The Audiophonics team is proud to be able to offer you a regulated linear power supply for the clean supply of small amplifiers, DACs, etc. This one has two lockable GX16 (aviation type) outputs, one outputting a voltage of 5V 1.5A and the other 12V 1.5A. GX16 to DC Jack 5.5/2.1mm cables with ferrites are supplied, as well as IEC C13 / Schuko cable. The power supply is equipped with a dual digital display and all components are integrated in a robust 100% Aluminium housing. This food represents one of the best quality/price ratio on the market.
Product typeLinear power supply
Input voltageAC 220V
Ouput voltage / current12V DC 1.24A
5V DC 1.5A
Power30W
Input connectorIEC C14 (IEC to Schuko cable NOT included)
Output connectorsGX16 2 poles (GX16 to Jack DC 5.5/2.1mm cable included)
RegulatorLinear Technology IC LT1085
Dimensions145 x 130 x 55mm
Weight3kg
Housing materialAluminium
Package1x Dual regulated linear power supply
2x GX16 2 poles to Jack 5.5/2.1mm cables
InputIEC C14
OutputGX16
Output voltage (V)5.0
Output voltage (V)12.0
Output current (A)1.5
Output current (A)1.25
Input voltage (V)230.0
Power SupplyLinear
4 reviews
super
Perfect price quality, fast shipping.
Only iec cable not included.
This review has been posted for AUDIOPHONICS Double Regulated Linear Power Supply 5V / 12V 30W T-Amp V-DAC2 LT1085
une vraie amélioration
il y a incontestablement une grande différence par rapport au cordon basique d'origine.
Tout est mieux défini, plus précis avec une meilleure dynamique.
Bref: n'hésitez pas !!
Attention: le cordon secteur n'est pas fourni..
Oubliez l'alimentation d'origine!
Avec un VDAC Musical Fidelity l'amélioration est franche: définition, plage, rendement... Bref aucun regret.
Un bémol toutefois: le cordon 220V n'est pas fourni...
Sobre et efficace
Bon produit, d'apparence robuste, et dont j'ai entendu l'efficacité de suite en alimentant un petit DAC Musical Fidelity pas tout récent et un vieil Onkyo NDS1, en lieu et place des petits transformateurs d'origine.
The Audiophonics team is proud to be able to offer you a regulated linear power supply for the clean supply of small amplifiers, DACs, etc. This...
