LPSU100 Linear stabilized power supply 5V 11A DAC / Docking
The Audiophonics team is proud to be able to offer you a regulated linear power supply to properly power digital players, storage devices, small audio systems, etc. This one has an output in GX16 format (aviation type) that can be locked and delivers a voltage of 5V 11A.
Reference : 8718
299,00 €tax incl.
249,17 € tax excl.
Linear Regulated Power Supply
LPSU100 Linear Regulated Power Supply 5V 11A DAC / Docking
LPSU100 Alimentation Linéaire Régulée 5V 11A DAC / Docking
The Audiophonics team is proud to be able to offer you a regulated linear power supply to properly power digital players, storage devices, small audio systems, etc. This one has an output in GX16 format (aviation type) that can be locked and delivers a voltage of 5V 11A. The GX16 to DC Jack 5.5/2.1mm cable with ferrite is supplied, as well as the IEC C13 / Schuko cable. The power supply is equipped with a digital display and all components are integrated in a robust 100% Aluminium housing. This food represents one of the best quality/price ratio on the market.
Product typeRegulated linear power supply
Input voltageAC 220V
Output voltage / current5V DC 11A
Power100W
Input connectorIEC C14 (IEC to Schuko cable included)
Output connectorGX16 2 poles (GX16 to Jack DC 5.5/2.1mm cable included)
Dimensions25 x 21 x 7cm
Weight4kg
Housing materialAluminium
ColorBlack, silver front panel
Package1x Regulated linear power supply
1x IEC C13 to Schuko power cable
1x GX16 2 poles to Jack 5.5/2.1mm cable
InputIEC C14
OutputGX12
ColorSilver
Output voltage (V)5.0
Output current (A)11.0
Input voltage (V)230.0
Power SupplyLinear
Très satisfait par cette alimentation et le processus d'achat.
A la recherche d’une alimentation linéaire délivrant 5V et au moins 2A pour alimenter mon lecteur réseau Bluesound Node N130 « tweaké » avec la fameuse carte d’alimentation de la société polonaise PD Creative, mes longues recherches m’ont amené sur le site d’Audiophonics.
Bien m’en a pris puisque je suis à présent l’heureux possesseur de cette LPSU100 en 5V et 11A, que j’ai pu acheter à un tarif hyper intéressant grâce à la promotion en cours (-40%).
Le coli est arrivé très rapidement en Colissimo classique (commande passée le mercredi à 23H, livraison le samedi matin) et parfaitement emballé.
Le boitier d’alimentation respire la solidité et la qualité, aussi bien des matériaux (alu brossé) que des composants. Il ne chauffe quasiment pas même après plusieurs heures d’écoute.
Et le résultat sur la qualité du son est bel et bien là. Tout ce que j’ai pu lire depuis des mois sur le sujet a été confirmé dès la 1ère écoute : les basses sont devenus plus précises et profondes, les aigus moins agressifs. Les instruments se détachent les uns des autres et la scène sonore gagne en espace. Les voix se montrent plus présentes.
Et surtout, surtout, l’écoute est devenue beaucoup plus confortable : il n’y a plus de fatigue même à un volume plutôt élevé. Je peux écouter à présent pendant des heures au même niveau du potard de mon ampli tout type de musique (même dans le répertoire metal dont les morceaux « occupent » très largement toute la bande passante) alors qu’avant cette alimentation, je finissais par baisser le volume voire même arrêter d’écouter par fatigue.
Bref, je recommande à 200% l’achat de cette alimentation auprès d’Audiophonics !
This review has been posted for LPSU100 Linear stabilized power supply 5V 11A DAC / Docking
The Audiophonics team is proud to be able to offer you a regulated linear power supply to properly power digital players, storage devices, small...
